Cleat install: 4200 or 5200? No Plan To Remove Ever. What Does Factory Use? >
Old 04-16-2016 | 09:39 PM
Default Cleat install: 4200 or 5200? No Plan To Remove Ever. What Does Factory Use?
I'm installing two cleats tomorrow. I have fast cure 4200 and 5200 here.
thirdchildhood is offline
Old 04-16-2016 | 10:31 PM
BigSilverCat's Avatar
Silicone is for stuff you may need to remove sometime. 4200 was designed for people that were not sure if they were doing something right and they could fix it later if they did it wrong. 5200 is for people that know there doing it right the first time, because there is no second chance.
BigSilverCat is offline
Old 04-16-2016 | 10:33 PM
They will both work just fine. If it was me I would go witht the 4200.
Revd Up is offline
Old 04-17-2016 | 12:30 AM
c_deezy's Avatar
I wouldn't use either. I would use silicone.
c_deezy is offline
Old 04-17-2016 | 01:17 AM
I used 4200 when I replaced the cleats on my Pantera. Worked well and does not peel up like silcone.
Griff is offline
Old 04-17-2016 | 06:28 AM
Never say never, I would go with a good backing plate and silicone.
Padraig is offline
Old 04-17-2016 | 06:31 AM
I made 1/4 inch thick aluminum backing plates. Not crazy about silicone so I'll probably use the 4200.
Old 04-17-2016 | 06:37 AM
Indy's Avatar
Member #154
Solvent for 5200?
http://www.boatingmag.com/marine-sol...-removing-5200
Indy is offline
Old 04-17-2016 | 09:55 AM
As "Big Silver Cat" said....Silicone. It should be under the cleat, not a fillet around it.
Taboma is offline
Old 04-17-2016 | 10:12 AM
onesickpantera's Avatar
I would use silicone or 4200. I would not use 5200 as you may want to replace them someday.
onesickpantera is offline
