-   -   What is the best place to mount transducer on Cat? (https://www.offshoreonly.com/forums/general-boating-discussion/336657-what-best-place-mount-transducer-cat.html)
insanedaddy 04-22-2016 01:20 PM
I am trying to figure out the best place to mount a transducer on a 30' Spectre Cat. I want to use an internal transducer. I don't want anything hanging off the back of the boat. I understand they don't work very good shooting through a core hull. Where is everyone mounting them on their Cats?
dereknkathy 04-22-2016 04:22 PM
I guess you dont want to punch a hole in the hull and run a thru hull, instead of a look thru hull transducer?
iliveonanisland 04-23-2016 11:02 AM
Its best you post up some pics of the boat and your girlfriend's bottoms... then we'll tell you where and how to mount them...rm
Taboma 04-23-2016 11:34 AM
I really don't think you will be able to get any accurate readings at speed due to the steps in a cat aerating the wet surface even if you mount the transducer on the outside layer of glass with core removed.
iliveonanisland 04-23-2016 12:01 PM
You think even the very rearward part of the hull next to the transom wouldnt work? Thats where i would mount it.
Try calling skater or one of the other cat builders... id be more comfortable cutting a hole in the coring back there too as that entire area is very strong... rm
insanedaddy 04-23-2016 01:51 PM
I talked to Jay Pilini and he said the bottom is cored and would have to cut a portion out and epoxy it in. I am not sure I want to do that. I am going to look at possibilities of mounting on the transom. With all the steps in the hull I doubt I would get a reading at speed like everyone has said. I may just not even worry about a transducer. The new Garmin I am installing has a pretty neat 3D down view, so that is the reason for the transducer.
drejustice 04-24-2016 12:12 PM
We are on our 3rd different way of mounting a transducer. This time DCB did a true thru-hull with a brass fitting. I'll still lose depth readings probably above 35-45 mph but that's also what gps/charts are for.
insanedaddy 04-24-2016 04:53 PM
Do you have a picture of the brass fitting?
drejustice 04-26-2016 01:40 PM
Sorry I didn't take a pic while out there...i'm still waiting for a few things to be finished and have them dial the boat in completely before I bring it back east.
Taboma 04-26-2016 04:16 PM
I researched and thought the same scenario thru when rigging my Skater. Settled for Garmin 7610's "Fish Eye View" for depths!
