trs to #3's
1) is it possible)
2) any gains? #3 over trs or is it apples and oranges! 3) if possible how much? thanks |
Do a search in the tech area. This is covered pretty well.
It involves, glassing, new tranny, full external steering, and moving the engine. Gary |
TRS to #3 is a direct bolt on. It will raise your X dimension and you
will pick up some mph. Props are not cheap. A friend and I were just talking about doing the same on his boat. |
Trs to #3 is NOT a direct bolt on.
As Gary said there is alot involved see tech area Trs to #2 Speedmaster is a direct bolt on. Mark |
A # 2 speedmaster is an inch and a half LOWER so it will lower your X. It's also about 3 inces longer so hydaulic steering is stronly recomended.
the #2 also requires more HP to operate . unless you are boosting horsepower you could actually go slower with that option. besides they are very hard to come by these days. good luck which ever you choose :cool:
F'ING COMPUTER!!!!!!!!!!!!!!!!!
I just typed out the whole process of changing to SSM3 from TRS & got booted before I could post it. In a nut shell.... Gut your engine compartment Glass up transom (at least 4-5" of the bottom of the existing hole) Carefully measure out the drive (drive shaft to prop shaft. My Cig has no steps, pads or notches in the bottom & we went with 4" prop shaft below the bottom. Most riggers will suggest 3-1/2 to 5" with 3-1/2 being the minimum to get on plane without alot of trouble. Find someone (Lake X) with a SSM jig to get all the holes drilled right. Your engines will have to be moved back approx. 3" (SSM trans tailstock is shorter than TRS. Hang motor/s from hoist to measure your new hight. Make new mounts with 3/8" alum angle iron. Invent shift cable brackets & misc BS. Gain: 4 mph, awsome rooster tail and no more TRS bombs going south when your far from home! Thanks Russ Houston & Expo for all the help!!!!!!!!!! Any questions, pm me Dave |
DJD and Gary are telling it like it is!!! I did it to my old 38 Fountain...just had too much HP for the TRS drives. The #3's were extremely reliable and worked well....I then took the 3's off and put on a pair of big shaft 4's and look out....five more miles per hour, an awesome rooster tail and a lot slower to get on plane. It is a fairly intense project, but it does work. Best of luck!
DMan |
Dreamer....what kind of boat are you doing this to and how much horsepower are you running?
DMan |
You are correct sir, it was #2's.
