-   -   Stringer issues, What to do now? (https://www.offshoreonly.com/forums/general-boating-discussion/337643-stringer-issues-what-do-now.html)
phragle 05-24-2016 07:42 AM
Iff you bust some ass you can do that repair in 2 weekends with a few after work sessions for a couple hundred in materials. Get the motor out, get some good piks and we will get you on the right track
BBCLiberator 05-24-2016 07:55 AM
That's the plan, I'll get the motor out on Saturday and get a better look at the damage.
92nsx 05-24-2016 10:35 AM
And I thought the engine mounts on my 33 outlaw looked weak.......
US1 Fountain 05-24-2016 10:40 AM
That top motor mount nut is about to come off. Unless you unscrewed it before taking pic, something is toast! You may be looking at a new coupler too and check TA for cracks around the bearing
BBCLiberator 05-24-2016 10:43 AM
Nope, I shifted both sides all the way up to get a better look, drive was already off at this point. I also loosened the bolts thru the stringer to try to see rot if any.
Team Archer 05-24-2016 04:07 PM
Next after you repair the stringer put a solid motor plate get rid of the stock mounts that will tie both stringers together with nice backing plates.
Wobble 05-24-2016 04:38 PM
Setting up the offshore mount the first time can be a pain, but it is a much stronger setup
BBCLiberator 05-24-2016 06:13 PM
I looked at doing that, but not sure yet is th CP performance one any good?
TxHawk 05-24-2016 06:17 PM
How much room between stringers?
BBCLiberator 05-24-2016 06:27 PM
I'll know this weekend and take measurements. Until then I guess it's useless talking about.
