-   -   Twin Turbo LSX Boat (https://www.offshoreonly.com/forums/general-boating-discussion/338630-twin-turbo-lsx-boat.html)
hogie roll 06-25-2016 07:42 PM
Twin Turbo LSX Boat
http://www.enginelabs.com/news/water...00-horsepower/
Someone's been holding out on us. Fess up Redder, what's this going in?
AZMIDLYF 06-25-2016 08:56 PM
Wonder what RPM they will be spinning this up to.
Smarty 06-26-2016 11:09 PM
I would think that would make 1200-1400 hp, but my assumption that motor would need a bigger turbo to get to 2000hp, I believe that is a 70 mm compressor, in the link. But I don't know sh*t, so teach me. Precision has some pretty cool equipment. Hogie, I like this post, I am all about learning what works, what are the right parts, combinations, and real world field testing/experience. Keep the info coming
hogie roll 06-27-2016 07:29 AM
The guy building them is on here, hopefully he fills us in.
wannabe 06-27-2016 07:41 AM
I've been waiting for this to pop up. The LSX block is perfect for building a light weight 1500 hp turbo motor. The block was designed for 2000+ hp.
Wannabe
86Capri 06-27-2016 08:13 AM
It is going in a older fountain. That was setup for twins and now a good running single. I also think it has a #6 drive behind it. Funny because I read the tittle and thought I know of someone building a 35 fountain like this. Then read the article yep that is the one I know of.
hogie roll 06-28-2016 11:39 PM
That's pretty cool. Wiesman should develop and promote his dual prop drive. With so much horsepower now you could power up to 40 foot boats with singles.
TBAG 06-29-2016 08:25 AM
Cool! Excited to see how it runs.
BDiggity 06-29-2016 08:34 AM
yes it has a #6. John can spill his beans...
http://i534.photobucket.com/albums/e...psquwuljik.jpg
TBAG 06-29-2016 08:47 AM
Yes please! Would love to see some build pics and hear more details.
Wasted Income 06-29-2016 09:00 AM
Not according to the article.
Mercer Machine and Performance out of Lawrence, Kansas
It looks like Retter supplied the A2W IC and maybe the water jacketed turbine housings from what I gather.
Maybe he will chime in with what he knows about it.
"Retter, RED, Precision, Retter Engine Development, Popeyes, hookers, buttsecks".......tags for when he googles himself, so Ryan will see this. lol
tommymonza 06-29-2016 09:16 AM
After reading the following article I became sold on the LS platform.
Wondering why people are still screwing around with big blocks and superchargers in boats when a turbo LS will do the job with more reliability .
http://www.hotrod.com/how-to/engine/...g-bang-theory/
Wasted Income 06-29-2016 09:36 AM
Ugh...please, please, please don't quote that Big Bang HotRod rag article. So many people read that and automatically assume that stock LS junk can make 1000+ reliably, then build one and scatter it at 650 rwhp. I have built and blown up enough stock bottom end turbo LS stuff to know for fact that is not the case. lol.
The fact of the matter is, we don't really know if the BIG hp LS stuff will truly live in a boat. Jimkid has proved that NA LS stuff (LS7) works really well in his skater. However, I have never seen data that says that the big inch big hp turbo LS stuff can live in a boat...but if it does, it certainly won't be a stock bottom end setup like HotRod had on the dyno. It's hard for me to say, since I'm one of the biggest turbo LS fanboys there is. I think for the article to claim that a 1500-2000 hp LS is more reliable than a BBC of similar power is a bit far fetched, and certainly premature.
AZMIDLYF 06-29-2016 10:23 AM
Weisman has a real clean AVS with twin LSX N/A motors in it. Cool video about LS building by Tom Nelson of Nelson Race Engines.
https://youtu.be/VsmbbuSq9m0
Cole2534 06-29-2016 10:49 AM
I need 2 of those in a small Skater.
tommymonza 06-29-2016 11:11 AM
I know a stock LS motor is not going to get the job done but a built for purpose 427 LS opposed to a 540 BB is probably about the same amount of money with less weight and better valve train.
So what's the problem?
corey331 06-29-2016 11:14 AM
Totally agree. I have had a bunch of buddies that have blown up stock bottom end LS motors with turbos that were no where near 1000hp. That's why I built the **** out of my bottom end just to be able to handle 600hp N/A in a boat.
Wasted Income 06-29-2016 11:37 AM
My point is, that a 1000 hp 427 LS is going to be working a lot harder to make that power than a BBC with 100+ more cubes. Buddy of mine weighed a 6.0L LS shortblock vs a new 540 BBC shortblock a couple months ago....the LS was 310 lbs, and the BBC was 360 lbs. 50 lbs isn't a small amount, but you could leave the cooler at the dock to make up for it. The fact is, with increased power density, comes reduced longevity.
If Merc was starting from scratch with the QC4V, why did they chose to go straight to 9 liters, instead of something smaller and throw more boost at it?
Ditto, I finally ended up with a bunch of nice parts in my 370 cube bullet. Seeing as how it puts down 825 hp to the rear wheels through a 4L80E and 12 bolt rear end, it's making right at or under 1000 hp at the crank, assuming 17-20% drivetrain loss. It runs great for short blasts on the highway, trips to the drag strip, etc.....but I don't think I'd trust it to pin it WOT at 100% load for a few miles at a time.
Though when I swapped the LS into my jet boat, I did like to run that thing balls out down the river...but it was only at 400 hp, and only turning around 5000-5500 rpm.
corey331 06-29-2016 12:08 PM
My weight saving was a lot more significant than that, but I also weighed dressed engine vs. dressed engine. My stock 310hp 454 was 1060lbs with iron intake, iron exhaust, iron heads and all the accessories. My dressed 408 LS2 is 560lbs. That's a 500lb savings over the 454, which is pretty substantial. I also decided to try the aluminum blocked LS2, which saves 100lbs over the 6.0 iron truck block. I know the iron is a little stronger, but at my power levels, the aluminum should still be just fine. If I ever go boosted, it'll get swapped out to iron. I will also concede that a lot of the weight I saved, could have also been shaved off a big block by switching to headers and an aluminum intake. My goal was to build a motor that was roughly equivalent to a hp500 in power and weighed a lot less.. I'm pretty sure fully dressed, I am still 250-350lbs lighter than a fully dressed hp500, and am making slightly more power. But my main reason for doing the swap, was simply to be different!!
Wasted Income 06-29-2016 12:24 PM
As I was reading your response, I kept thinking "yeah, your boat anchor ALL iron 454 is was heavy....and configured much differently than a "max" effort BBC".....then you covered that point. lol. good work.
I don't have the weight for an LS2 shortblock, but my buddy did weigh an LS1 at the same time, and it was actually 130 lbs lighter than an iron 6.0....figured you would get a kick out of that info, since there's lots of different numbers floating around the net, which is exactly why he weighed them all.
Thanks for the weight numbers on your swap. Certainly very interesting. I wish I had a heavy duty enough fish scale to compare the 454 from my jet boat with the LS that went back in.
TBAG 06-29-2016 01:16 PM
How is the boat doing so far? I really hope to run into you one day on Cumberland and check it out in person.
corey331 06-29-2016 01:24 PM
Been fighting reversion issues, so I had to dry up the exhaust. Heading down this weekend to re-install the headers. Hoping to be on the water Friday!!!
TBAG 06-29-2016 02:35 PM
Nice, good luck bud, hope you get to enjoy the weekend on the water!
Wasted Income 06-29-2016 02:36 PM
Get some vids too. I bet it sounds great with the dry exhaust.
corey331 06-29-2016 03:25 PM
Will do!!!
