-   -   Scarab 29 advise needed (https://www.offshoreonly.com/forums/general-boating-discussion/339145-scarab-29-advise-needed.html)
louisfever 07-11-2016 01:59 PM
Hi guys
Im thinking about installing a 12 inch extension box to my scarab 29 and would like to know if anybody has done it ..
Has anybody out there installed an extension box on a scarab 29 and did it make any difference in ride quality and speed ???????
My motor is a 570Hp 502 I built
Thankss
blaquebaja 07-11-2016 04:55 PM
What's the spec on your 502?
louisfever 07-12-2016 01:24 AM
9:1 cr carburated 502
800CFM carb
Dart 308 iron eagle heads with Inconel valves
Camshaft from the 525EFI mercury racing motor
louisfever 07-12-2016 01:25 AM
Short block was rebuilt a year ago
Team Archer 07-12-2016 11:31 AM
The main thing to remember is that when you go back you need to go up also. 12" back equals 1" up.
louisfever 07-12-2016 12:19 PM
Yep I know that thanks
I was told to go up more !!!!!!
I was told to go up 3 by a pro in the marine industry !!
Team Archer 07-12-2016 01:33 PM
That's because all Scarabs the drives are mounted too low we put 2" shortys on most of them whitch helps a great deal
louisfever 07-12-2016 01:41 PM
Last winter i closed the transom and raised my X dimension 3 inches
Brought the slip from almost 20% to14 - 15% which is great and gained 3 mph !!!!
My nose cone now is aproxx 4.5 to 5 inches below the Vee of the boat !!!!
If I put an extension box on it, should I raise the height another 2 or 3 inhes again or keep my height and go with a neutral box ?????
louisfever 07-13-2016 01:35 AM
Im sure it will help the boat by setting back the drive but im scared it wouldnt have enogh leverage if I go higher then I am !! (being 3 inches higher then stock)
scarabman 07-13-2016 06:24 AM
If you go with a neutral box, you are pigeon holed with what you can do. If you go with a + box, and you can always space back down. At the very least, if you are happy/comfortable with your current setup, as was already mentioned you need to go +1 to maintain.
louisfever 07-13-2016 09:27 AM
Exactly buddy since I raised 3 inches the boat runs great but dont wana raise it 3 inches cause I use my boat in the rough and wana stay hooked up ....
Im gona raise it 2 inches and 12 inch back ....
as you said I can always go down that inch if i have too ....
Im hopeing the cleaner water and the raise will allow my to run a higher pitch prop !!!!
Im at 5200 with a bravo P24 at the moment
Do you thing the motor will spin more with this modyfication ?????
