-   -   Running 90mph plus in 30ft or less vhull (https://www.offshoreonly.com/forums/general-boating-discussion/340432-running-90mph-plus-30ft-less-vhull.html)
cagedlx 08-18-2016 01:35 PM
That old 29 race boat of reggies and then trents ran in the 80's. Trent told me it was all over the place at those speeds. and that was a single engine boat! Be careful!
twin242ls 08-18-2016 02:44 PM
Andy that puts you at about 9%slip if you turned 30s at 9% at 5600 you would be in the high 90's but 9% is wow But If you want to try my Bravos from my formula you can give them a shot they are 28's pitched to 29 and labbed. you should be able to turn those 56-5800 and see what they do. I will be at boaters on Saturday
Andrew
laneab2 08-18-2016 08:58 PM
i have a set of 30pitch bravos I'm trying this weekend ill see how they go, i am tuned to rev 5650 rpm hopefully i can get close to that and find a sweet sport on the pad
laneab2 08-18-2016 09:02 PM
I'm probably going to switch to 380s this winter and see how that does, for now unless I'm alone or with someone who knows to hold on i tab to 5 and run 81-82 at 4800rpms
twin242ls 08-18-2016 09:02 PM
That should be an improvement you should pick up another 200 rpm with those 30's labbed 30's could be the ticket. Let me know you are welcome to try them any time
Toffen 08-21-2016 03:57 PM
Originally Posted by Dean Ferry (Post 4472573)
Impressive!
Hi!
Is this a Phantom hull?
Cheeers, Toffen
sutphen 30 08-21-2016 07:13 PM
Originally Posted by laneab2 (Post 4472329)
Recently purchased a 29 fever with big block twin motors, first time ever owning a boat that's anything faster than 70 mph wot just looking for similar setups and what people have done to achieve the "sweet spot"
Current set up
98 single step
Twin 540 EFI
XZ drives with -2 Sport masters
32 Bravos that need replacing edges are junk
Currently tabs at 4 drives at 4.5
Revving 4950 5000 RPMS at 91mph
With some aggressive chine
how are you determining speed?gps or speedo?
bor 08-22-2016 10:47 AM
Originally Posted by Toffen (Post 4473354)
Hi!
Cheeers, Toffen
Hi toffen ,
Yes it is there s a build thread on boatmad forum .
unfortunatly it s not a steve baker one but from another mold couldnt figure out from who as I know quite a few that copy the hull but we have cut hull and deck when got here and start over all stringers , transom and floor construction even put a bulkhead in front under the deck , build to last !
Cheers
Armand
T-Mone 08-22-2016 11:46 AM
My buddys superboat y2k runs 106 on rails
Drake22.250 08-22-2016 12:26 PM
Use to run a 25 foot sunsation aggressor with twin turbo gale banks set up on a 454. Cop radar gun said 87 but she had a little more in it. Wife would beat the **** out of me after 80 with all the chine walking. Fun boat...for me anyways.
