Running 90mph plus in 30ft or less vhull
That old 29 race boat of reggies and then trents ran in the 80's. Trent told me it was all over the place at those speeds. and that was a single engine boat! Be careful!
Andy that puts you at about 9%slip if you turned 30s at 9% at 5600 you would be in the high 90's but 9% is wow But If you want to try my Bravos from my formula you can give them a shot they are 28's pitched to 29 and labbed. you should be able to turn those 56-5800 and see what they do. I will be at boaters on Saturday
Andrew
Andrew
Recently purchased a 29 fever with big block twin motors, first time ever owning a boat that's anything faster than 70 mph wot just looking for similar setups and what people have done to achieve the "sweet spot"
Current set up
98 single step
Twin 540 EFI
XZ drives with -2 Sport masters
32 Bravos that need replacing edges are junk
Currently tabs at 4 drives at 4.5
Revving 4950 5000 RPMS at 91mph
With some aggressive chine
Current set up
98 single step
Twin 540 EFI
Hi toffen ,
Yes it is there s a build thread on boatmad forum .
unfortunatly it s not a steve baker one but from another mold couldnt figure out from who as I know quite a few that copy the hull but we have cut hull and deck when got here and start over all stringers , transom and floor construction even put a bulkhead in front under the deck , build to last !
Cheers
Armand
Cheers
Armand
