-   -   what to believe ? (https://www.offshoreonly.com/forums/general-boating-discussion/340577-what-believe.html)
Dave M 08-24-2016 06:24 AM
Originally Posted by 93 shooter (Post 4474407)
honestly ,i am a little confused.so if the scan that was sent to me is truly for this boat,the scan hours are most likely correct and the gauge hours are inaccurate?
The hour meter WILL record hours with just the key on, the motor WILL NOT. With that said, all the boats I've owned had the stereo wired hot, so no need to turn the key on to use the stereo.
When you turn the key, listen carefully to the hour meter, you will here a little click every 10th of an hour.
rak rua 08-24-2016 06:29 AM
Yes.
Check the scan for the engine number, make sure it is the engine that is in the boat. Simple.
RR
93 shooter 08-24-2016 06:34 AM
thank you for clarifying this for me.
93 shooter 08-24-2016 06:40 AM
Originally Posted by rak rua (Post 4474417)
Yes.
RR
i will ask seller to send me picture of the engine number so that i can match to the scan
thank you
rak rua 08-24-2016 07:37 AM
Engine numbers are sometimes hard to find, let alone photograph. He should also have some registration, coast guard documentation or even insurance papers that show the engine number. If you're agreeing a sale 'unseen' make sure it is written on the contract, "subject to and conditional upon verification of engine number".
You should have no problem, all sounds genuine to me, in which case he will understand your cautious nature.
Good luck!
RR
93 shooter 08-24-2016 07:58 AM
Good luck!
RR
thank you again for the additional info
93 shooter 08-24-2016 08:04 AM
Good luck!
RR
just sent seller email asking for documents,will see what happens
Wasted Income 08-24-2016 11:41 AM
Originally Posted by rak rua (Post 4474342)
Don't forget, with engine hour scans, as I understand it, you can have the scan reset back to zero for the scan of rev range usage but the total hours cannot be reset. (This applies to Verados and I assume it also applies to inboards).
This is also true of PCM 555 used on the 496
erik1976 08-24-2016 02:53 PM
I have my truck driver delivering steel 1/2 hour away from there on September 6 and he'll have some time to kill. If you don't make a deal and are still interested then let me know and i'll have him stop over for a look. He's not a boat guy but he is a mechanical guy.
Erik
93 shooter 08-24-2016 06:30 PM
Erik
wow, that is awesome of you. I will let you know
thank you so very much
