-   -   Tandem or triple axle trailer???? (https://www.offshoreonly.com/forums/general-boating-discussion/34079-tandem-triple-axle-trailer.html)
Bulldog 10-01-2002 09:09 PM
In the event of a blowout, I think that a triple would probably handle better while getting to a safe spot to change the tire. A triple will also give you extra margin before the front tire falls off the ramp when backing in deep. My main runners and drive guard are 8 inch channel- steel- and definitely protect the drives.
Bulldog
GotTheFever 10-01-2002 10:08 PM
I have a triple axle for my 32’ Fever. It handles very well. I was blowing a lot of tires so I had it aligned ($200). Since then, it’s been kind to tires. You just want to watch your turning radius. If you scrub the tires too much, you can bend the axles. Triples also look more impressive going down the road.
boot 10-01-2002 10:44 PM
32fever, What I think he ment by "you can run without one tire " on a triple , is You jack up that axle , remove the tire , and chain the axle up to the frame then let it down . This is very common . I've even done it with a 3" nylon strap just wrapped around the axel and frame and tied it . It worked in a jam !
Also on you backing problem , Your trailer has the wrong brakes on it . It should have "Free baking brakes " .BUt since it doesn't , they have a little $20 solinoid (sp) you put on the front of the trailer and hook into your backup lights . When in reverse the solinoid keeps it from building pressure to the brakes . Hope that makes your life a little easier ....;)
Sydwayz 10-01-2002 10:52 PM
Who did your trailer alignment??????
paradigm shift 10-01-2002 11:14 PM
Triple all the way. I like the looks of 3 axles and I also think they smooth out the rough roads a little better. I also heard all the horry stories about turning and rolling tires. Never happened yet but I keep my tires pressure up. Only time I cuss it is when it is time to service wheel bearings. Just my .02
As long as you get a trailer set up properly you would be happy with either 2 or 3 axles.
Tonto 10-01-2002 11:46 PM
boot
You beat me to it :p On my fishing boat, it has surge disc brakes, it has a solenold on it that takes the brakes away by opening the flow of brake fluid back to the resevoir when backing.
The only way I would tie up the axle to tow is if the remaining two tires/axles could carry the weight of that side of the boat, and yes you would mess up the alignment by not having all 6 tires on the ground.
As far as stability when having a flat with trips..... I have a wheel that I'm saving from one night towing the Formula to S. FL. that is worn flat :D Never knew I had a flat until the bead wire from the tire locked the brakes up and did the sparks fly then :p
Robert
29 OUTLAW 10-02-2002 07:01 AM
Triple axles trailers make your boat look bigger.
Actually I got a triple so that I could loose a tire and still tow to a safe place.
Flashwave 10-02-2002 08:43 AM
Triples all the way. Have towed F1-48 (29' about 7000 lb.) over 50,000 miles this year mostly at 75-80 mph. Had a truck hit us in San Antonio that took out the right rear wheel, tire and bent the axle. We strapped up the axle and ran into Corpus on 5 tires. Towed just fine. Disc brakes will cause you less problems than drums.
JIm
