5/8 Fuel Pick Up
I can not remember the company that I order 5 /8 inch fuel pick ups to install in the fuel tanks as it was a couple of years ago. Also last year I ordered 1/2 inch fuel pick ups from another company and can not find the invoice to call them asking if they have 5/8 as well. Anyone know who has these and I will need to cut to length most likely also just an FYI will be using # 10 AN fuel line connections to the pick up. Thanks for the help.
Seems like that is something you could weld up or have welded up, just need a fitting and some tube
I had a lot of trouble finding one until I googled diesel fuel marine pick up. Don't remember where I eventually found it.
Try a company out of edgewater Fl called Centroid Products. .Tel # 386-423-3574
If you are going to weld them in the tank, I' sure that a section of aluminum tube, or pipe if you want threads on one end, would work just fine. I'm pretty sure that whomever is up to the task of properly welding them to the tank would find it to be no problem making them.
Suggest Florida Marine Tank in Henderson NC
| All times are GMT -5. The time now is 05:46 AM. |
