-   -   Looking for input about this video of surface drives (https://www.offshoreonly.com/forums/general-boating-discussion/342012-looking-input-about-video-surface-drives.html)
No Coast 10-22-2016 06:46 PM
Just to be clear the Ben Robertson video shows either Speedmaster number 6 or M8 drives, not surface drives. The camera is mounted in the notch of the transom. At high speeds the goal is to obtain 40% propeller engagement in the water and 60% out of the water surfacing, essentially the lower section of the propshaft bullet should be on the surface of the water. This video shows perfect X-dimension drive height in my opinion, for a high speed application.
302Sport 10-27-2016 05:46 PM
What are you Arneson guys seeing for slip and what was the worst slip % you've seen??
502ss 10-28-2016 05:49 PM
I am not running arneson but instead kaama's. I am averaging about 16-17% with my 3 blade props. The worst slip I saw was about 50% when I was still learning to drive with the kaama's and that's because I had them pulled 3/4 of the way out of the water! :( live and learn!
kjm5125 10-28-2016 07:22 PM
One of the best!
professor_speed 10-28-2016 08:32 PM
when a stern drive is that high and spinning the same prop is there really much difference?
professor_speed 10-28-2016 08:33 PM
Double post
