-   -   sound isolation?!? need help (https://www.offshoreonly.com/forums/general-boating-discussion/34319-sound-isolation-need-help.html)
timucin 10-05-2002 05:13 PM
who makes best sound isolators?
solid or soft compound?
where to buy?international shipping avaible?
any idea about price?
will use them for engine walls ( in the boat)
thnx for any input
Intolerant1 10-05-2002 05:34 PM
Talk to an engine builder who has a dyno room. My buddies shop has the foam "bumpy" panels insulating his dyno room and it works great. If nobody comes up with a source for you, Ill give him a call.
Tinkerer 10-05-2002 07:31 PM
Call the TIARA boat comp. They use sound insulation in their boats
Tom 10-05-2002 08:19 PM
I have found that sometimes it is better to go to the source that works in acoustical barriers (or whatever I need) than to rely on what a boat maker found and is using. Other times it seems that boaters did a lot of trial and error to come up with what works. In seats for example it blows me away that people are not using space age foam in their seats. Car racers are and they don't take any pounding compared to Offshore. I think sound isolation is the same. These guys know all about sound isolation. Try the link below.
Link to Accoustical company
Audiofn 10-05-2002 11:49 PM
Get me a picture if what you are trying to do and I may be able to help you out.
Jon
apache77 10-06-2002 01:18 AM
are you trying to reduce high or low frequency?
or vibration?
are you trying to reduce noise for the pass or spectators
Big Boys Toys 10-06-2002 06:01 AM
Sound Insulation for Boats
Timucin,
If you are looking for a real good sound insulation barrier, there is a place in Marblehead Ma. called Sounddown. Their Phone number is 781-598-4248 They make large boat mufflers and special insulation for boats.
The boat insulation has fiberglass on one surface with a thin layer of Lead in the Middle with another Layer of fiberglass on the outside with an aluminum face that has small fibers running through is as support.
You can cut the stuff with a sharp razor knife and pair of heavy duty shears.
Good luck with your project.
Brian
timucin 10-06-2002 05:36 PM
1 Attachment(s)
thnx all for your help.
BigBT: will call them on monday
Apache77:trying to reduce sound .will be seating infront of twin bigblock engine and there is only one fiber wall between us.I will isolate both sides of this wall to reduce the engines sound.
Audiofn:will take pic on monday and can post it on tuesday.this is a straight wall between engine room and cockpit
Tom: xtra thnx for the link.I think these are the compounds I am looking for.
thnx
Steve 1 10-06-2002 06:02 PM
Timucin your Builder used Airex Good choice there, But Why 10 MM ? Firewall Bulkhead 25 MM I would Think. Also in front of the Cockpit is there a Deflector system ?
timucin 10-07-2002 01:36 PM
Steve
no deflector yet, but planning to add .
