Canale Takes Ownership of Sonic Powerboats
#31
IMO there has been NO advancement in mono hull bottom design, basically if you want to go real fast, you switch to a catamaran.
Seriously, where do you go with a single hull design? Add a pad, add more strakes, maybe some steps? And steps are something that helped back when the speeds were much slower and the weight was much higher.
Most builders claim they add speed, most builders have also seen more issues...some have flipped, rolled, spun-out, etc...now you need lessons on how to turn, how to slow down and whatever.
Offshore racing is (or was) NOT about top speed in smooth water, going in circles...it was about challenging Mother Nature as you went "offshore" where you could not see any land, and you hoped that nothing broke and that you could find the checkpoint...to point A and back, NO BLACK FLAG, just man-up and hold on.
#32
#33
I'm very serious.
Bottom technology? Wow, sounds sophisticated. Thats is actually entertaining considering this is the marine industry that is stuck in the 80's.
There is NO technology being used in this industry at this time, NONE...with the exception of lamination techniques, and I guess we can say the electronics and controls.
The speed increases you mention have been from massive HP, lighter weight and longer running surfaces. Do you know the origin of the Outerlimits? The fountain? Most every one of the so-called faster designs are all related in some way, to the little Magnum of years ago. Actually, I'll say the Stepp Velocity 30' and 22' were a departure from the Hunt designs.
Answer this - who has actually utilized technology for boat design research? This is a caveman industry, why? The returns are not there to invest into real technology. Who has calculated the mass, versus drag, versus air flow, resistance and etc. Who has employed wind-tunnel efforts? Who has actually utilized CAD/CAM? Answer? Not one single US (hi-performance) boat builder has invested into modern technology...the closet they have come is "drawing" the boat in a computer, and "dragging" a model thru the water. Nobody has designed in the computer, they simply draw it in 3D and then use that for cutting foam for a plug. I'll bet that an 18' Sea Ray has more technology in it than any hi-performance design out there...including Mystic, Skater, Outerlimits, MTI and etc.
You're welcome!
You're welcome!
#35
Granted, Harry does not design hulls to be uber fast between two bouys on a market course on a salt river with a current and a tailwind; while factoring in the moon's position to ensure the tide is going out so the course is actually downhill...
...but he does use a ton of technology in his hull designs; has for years.
#36
#37
Check out the specs on the 1997 35 and 38 Fountains vs the 2007s. The weight of the boats didn't change but both models picked up 15 mph with the same power and they did it via improved hull design, going full stagger vs side-by-side, and improved props that allowed higher X dim. Lighter weight had nothing to do with the speed increases.
#39
You do know how they used to come up with their weight numbers, right? ROFLMAO....you read to much.
Please explain how a "full stagger" makes a boat faster? And you claim lighter weight had nothing to do with it?
C'mon, man...
I'm sorry, but sometimes people just say funny things.
#40
Seriously dude?! You're killing me.
C'mon, man...
C'mon, man...
