Water Heater question? Tankless??
Trying to figure out if a Tankless water heater will supply enough hot/warm water for a short shower?
What units are being used for this? Don't have space for a tank unit. |
We have an entire house operating a Bosch tank-less unit -- YOU CAN'T RUN OUT OF HOT WATER!!! Now this is a gas unit and I have no experience with electric systems but I'm sure they have been offered in other "RV" applications and I personally wouldn't think twice about getting one. The issue that you may experience is within your boat are you running a water softner - if not there is a potential for the heat exchange system to get mineral deposits and clog.
all the best 3pointstar |
With the on demand water heaters it is all about temperature rise. They will only raise X amount of gallons per minute X amount of degrees.
Up here in MI people that bought on demand water heaters when we have very cold winter temps have a surprise when they can't get a hot shower. When you have city water the water lines are buried 6 or more feet down and can freeze if it is cold enough long enough. The on demand water heaters can't heat this very cold water up enough to have a decent hot shower. |
We have an electric one on a boat, It works OK..... you have to adjust the flow rate according to the temperature of the incoming water and it requires a dedicated 30A breaker and line.
Used one on a catamaran sailboat I rented for a few weeks.
It was propane. Absolute endless hot water as long as you had plenty of propane. |
I have a Rinnai tankless propane water heater in northern New York. I have Endless Hot Water
Originally Posted by Tinkerer
(Post 4519143)
Up here in MI people that bought on demand water heaters when we have very cold winter temps have a surprise when they can't get a hot shower. When you have city water the water lines are buried 6 or more feet down and can freeze if it is cold enough long enough. The on demand water heaters can't heat this very cold water up enough to have a decent hot shower. But regarding the underground water lines freezing, it was explained to me by a physics teacher long ago; the temperature of a well digger's arse near the surface is close to whatever the ambient temperature is, and the temperature of a well digger's arse at 6ft below the surface will be around 42-50*, and almost always above freezing. Yes, occasionally underground lines freeze and burst, but there's a reason you can get well water in the winter, a reason for the frost line, and a reason geothermal pumps work- geothermal heat. So even at 33*, a decent sized unit will churn it out at 105-110* and 3gpm. Below that, nobody gets a shower- not you, or the neighbors, because the pipes would be frozen. https://www.libertywholesalesupply.c...ai_flow_chart/ Power outages....The power outage situation can be handled by a backup that sparks the pilot, so as long as you have fuel you have hot water. In the old days that 40 gallons of hot water in a tank meant you could shower before the power company got to work. With electric that's a moot point. We have a Rinai in our house, never had a cold shower. Flushing the heat exchanger with a bucket, pump, and vinegar is a routine maintenance requirement. I would never recommend tankless to a man with a wife and daughters; your bathroom will be a sauna and you'll never be able to drop a deuce. A friend had a couple 110v tankless units in his cottage when he first bought it. The sink was always good pressure and temp, but the shower didn't work as well. He switched to a whole house propane unit, they regularly have a half dozen people showering on weekends and no one gets a cold shower. Just prepare to have a bath fan the size of helicopter to get rid of all the moisture. |
Western NY, on city supplied water, my gas tankless works fine. Been using tankless for at least 20 years.
Padraig |
The only way to really solve this is two boats, one with a tank, one tankless. Put good looking women in each, and record the results for scientific purposes. Feel free to post the video footage. Purely for science and advancement, of course.
Originally Posted by class6
(Post 4519196)
If it`s the same over engineered, maintenance hungry, always something going wrong, pieces of **** like the residential units which I refuse to install then I`d pass.
Originally Posted by ICDEDPPL
(Post 4519369)
I know the tankless water heaters work great on gas or a high voltage. What I was trying to find out was can a 115volt 1800 watt .04 gpm unit used during summer months heat water enough to make it useable?
Originally Posted by excursion
(Post 4519469)
Using it for an actual shower? No. A normal shower rolls 105-120* at 1.5gpm(low-flow) to 2.5gpm(average). At .4gpm (and roughly 95*), it's going to be about like a dog pi$$ing on your leg. Those small POU units are designed for tepid water from low flow sink faucets. |
Check the specs out on this one:
https://www.titanheater.com/proddeta...?prod=SCR2-N10 But if you're on 30a shore service, you're going to be showering by candlelight. 26* rise at 1gpm and 18* rise at 1.5gpm, though. Tolerable. |
Ended up going with Chronomite SR-15 120 has a 31 degree temp rise and only pulls 15 amps only need the water to be comfortable. Will see how it works.
Gas ones work well, electric, not so much. My electric draws 36,000 watts, thats 3x50amp at 240V to get a good hot decent shower. Go gas..
Get an old blow up mattress .put it on youre t-top or bow ,fill with water insall small drainage hose and ,go out on a sunny day. Wallah = hot rinse water
Spray self down w Simple Green- Jump in Lake- Clean! Wife mayNot appreciate tho lol
| All times are GMT -5. The time now is 12:12 PM. |
