-   -   Twins (https://www.offshoreonly.com/forums/general-boating-discussion/345080-twins.html)
HacknWack76 02-28-2017 08:13 PM
Twins
How big of twins can you run in an '88 261 Four Winns Liberator that currently has twin 5.7 sb - Thank you
Cory H 02-28-2017 08:32 PM
Sky's the limit. Question is, how thick is your wallet?
Drew555 02-28-2017 09:52 PM
Can't start a thread with " twins" and think we aren't looking for boobies
rak rua 03-01-2017 04:25 AM
So your answer would be "bigger the better.........."
Dave M 03-01-2017 06:47 AM
Did any of those boats come with big blocks? Not trying to burst your bubble but if you end game is SPEED, that hull is NOT going to yield great results.
BOATMAN302 03-01-2017 07:27 AM
Yes they did come with big blocks. 365s if i remember correctly. 73ish mph as opposed to 57ish with 350s.
corey331 03-01-2017 07:59 AM
Twin 400ci+ LS's should do the trick!!!
boomer 03-01-2017 09:35 AM
That one heavy boat so as long as it is still solid I would think what every you had to spend, but at some point that boat will only go so fast.
tommymonza 03-01-2017 10:16 AM
I remember when century brought are old 26 Monza design to the Powerboat test with twin 365 mags.
Thing got so out of shape at any speed above 70 that they gave up on trying to clock a top speed and said Century needed to go back to the drawing board .
VoodooRob 03-01-2017 10:36 AM
I would think you would want to install external steering/drives/props/engines to build a safe usable package. Plan a budget, and in the end it will be double the dollars you figured and the boat will go 1/2 as fast as you calculated. Welcome to modifying a boat.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
