Stressed Engine Block???
I'm about to pull the trigger on a 1989 Pachanga but have a serious concern with one of the blocks. The owner is an engine builder and has assured me the pic is the issue and the block is just fine. His work appears meticulous but I think he missed this. I have altered the contrast to help illustrate the area of concern. Should I be concerned this motor is under too much stress or going to easily fail? http://www.uppersetting.com/personal/stress.png
He couldn't b meticulous if he missed that amount of cracks. I wouldn't waste my time with it
Originally Posted by 2jz
(Post 4535056)
Have him wipe it down and send new dated pics..........
Doesn't look typical for stress cracks though a few could be
Big Johnson builds some awesome motors you`ll be fine.
It looks like the assembly lube I use it is so stringy it will leave marks like that every where.
Just looked at it blown up they are not cracks. |
Yes I would say assy lube also .......those do not look like cracks in cast iron
Its too shiny to be stress cracks, it looks like it is on the outer cylinder too. And unless the engine is making 1500 hp its not under too much stress. Ive seen stock block BBC making that much on spray .
Originally Posted by midwest272
(Post 4535142)
yes i would say assy lube also .......those do not look like cracks in cast iron
They are not stress cracks. They definitely look more like oil/lube etc. Also, who would spend the time/money to do a rebuild/refresh on a block with gross cracking if that's what that was? You'll be fine.
Stressed is a under statement, I've seen a block shaken like a dog $hitting razor blades when a couple of guys I know get around a block with a wrench in there hand.
Originally Posted by 14 apache
(Post 4535139)
| All times are GMT -5. The time now is 02:12 PM. |
