-   -   Marine Application Serpentine belts (https://www.offshoreonly.com/forums/general-boating-discussion/346812-marine-application-serpentine-belts.html)
BUP 05-10-2017 11:06 AM
Yes I did remember a NAPA owner up here in IL from a past post so I know it was you now. Thanks for the help, prob will hit you up for needing info about specifics on some NAPA parts. Thanks again
BUP 05-10-2017 09:50 PM
This is what I get for listening to the guy at auto zone. I knew that Auto Zone has a belt measuring device in the back in which I did not see any of that end take place. He comes out and tells me my Volvo Penta belt is 915 mm and gives me the Dayco saying its 920 mm. Anyways later today, I starting thinking about it and looking at the belts - that did not sound right on the mm measurements - So I ended up measuring them myself -- he gave me the dayco inwhich was 2352 mm and the Volvo belt is 2343 mm outside diameter I came up with measuring. As stated both are 6 ribbed. Almost a match but IMO a tad big is the Dayco and used belt that has mostly grown a tad.
Anyways I really need a 2343 mm or very close to it. I know Bando has a 2345 mm I do not know what Gates has. Thanks and sorry for the miss info on my part. Prob 2340 mm thru 2345 mm is ideal but maybe 2340 since used belts gain a tad in length over time.
TylerBurich 05-11-2017 07:15 AM
LOL, The Auto Zombies will get you every time! .... Check out a Gates/Napa 25-060915.. That is 6 Rib 2340mm O.C.
SB 05-11-2017 07:52 AM
Just like our Autozone and O'Reilly's here :readinghelp:
https://img.ifcdn.com/images/c6ca359...8a0a7b0d_1.jpg
https://s3.amazonaws.com/static.cart...793586c4eb.jpg
BUP 05-11-2017 10:17 AM
Thanks again
I think they used something this in the back to measure belts with.
https://www.ryderfleetproducts.com/r...FdG3wAoddkwEnQ
BUP 06-23-2019 06:33 PM
So who has the low down on how to read serpentine belts and V belts to cross over. I have some marine apps that have Gatorback Goodyears belts and Conti now owns all that.
Is there an instruction or even a belt manu video on how to read the different belt manu numbers listed on these belts. Seems like none are same for listing the numbers and letters.
I used to be able to cross all belts but still can not find any info on the end.
BUP 06-23-2019 06:37 PM
995K6 mfg by goodyear so 6 ribs and 99.5 inches --- is that correct ??? Its a gator back because of the slits in the ribs.
The K is for pitch or depth of the rib which is correct ? pitch or depth for the K ??
Baja_260 06-23-2019 08:46 PM
Yes for that type of part number designation, 995 means 99.5" outside circumference. K means the rib is .140" wide and 6 is the rib count. Most local parts stores have a tool to measure the outside circumference if you can't find a cross reference to the part number. Also, every auto and marine application I've worked on in the past couple decades uses "K" width ribs.
If it helps anyone, I use Continental 4060822 belts on my 500 EFI's. $17 each from RockAuto vs $95 each from Merc.
