big HP engine maintenance???
speel chekk this fokker!
what kind of maintenance schedule would one expect from 600" 1000hp blower engines? (assuming normal responsible engine usage, no real long WOT runs, keeping the boost levels down while cruising, ect.)
rebiulds at 50 hours? or can they reasonabley make it longer??? What do these 50 hour rebiulds entail ($$$)? are we talking new valves, spings and gaskets ect. or total tear downs with major machine work?
what kind of standard maintence? oil changes, plugs, and the basic crap every couple hours? or do big HP engine need "other"
maintence?
maintence?
Pardon me, while I whip this out!
Registered User
My schedule With 6lbs boost, 92 octane mild timming is as follows. Oil changes every 10 hours with a check of vales. End of each season (about 75 hours) top end tear down and replace the lifters(1 inch lifters)150 hours complete tear down, bearings replaced and a very, very close inspection of everything,EVERYTHING.Otto
how much does the 150 hour tear down and inspec usually cost??? ballpark?
How many hours do you plan to use each season?
What about pulling the rockers at the end of the season. It seems that valve springs are a problem and leaving some compressed for 6-9 months is no help.
i usually run abotu 50-75 hours per season. But if i move to FLA (stll a possibility) i am pretty sure I would be runngin more hours especially becau eth season lasts all year. FYI i have yet to buy the boat or these big engine I just wnt to make sur ei'm not getting in ove rmy head financially.
never had that type of engine.but reading & searching detailed info about them for a long time.
36spectre ; probably knows better then me but my personal idea is 2much HP is 2much TROUBLE.
keep low - keep'em around 600-650 hp and enjoy boating
most of the big problems I've had were related to other stuff takin a ****. Just cracked a piston because of a leaking header. Overheated because I sucked up seaweed and melted a piston. Broke a valve and it went thru a piston. Its little stuff that ends up eating me alive.
