502 oil capacity with relocated oil filter
What should capacity be? New purchase and when cold and level ground dipstick shows about 2 inches above full mark? I took to local dealer to get shift cable adjusted and they told me it didn't have any oil showing on dipstick....then they tell me they checked it running. lol I know right....thanks
I think thats the wrong dip stick, unless its way over full, I think a gen 6 502 has an 8 or 9 qrt + the filter, lines and cooler
Checking it while running ?? find a different shop...... |
Actually , the best time to check it is when airborn just after launching off a big wave. If you land before you see the oil level, do it again. :lolhit:
Lol....
I'll try that sb....lol
The first launch I was seeing about 40 lbs at idle and 60 running about 3200
Is it a Merc 502???? If so, it holds 8 qts if 100% empty. 7.5 qts is what gets me to the full mark when I do an oil change on my 502mpi's.
Check the oil with engine level. This is the same as it would be sitting at rest in the water. |
Yes it's a merc. And thank you I will check on next launch
Mine with filter is a tad over 7 quarts with filter WIX 51060R
| All times are GMT -5. The time now is 10:56 PM. |
