Loud BANG sound- new Merc Racing 565, DTS, XR
Hey fellas... looking for some guidance.
Twice now, I have got a loud BANG sound when initially (immediately) starting to throttle up to get on plane. Backed off immediately, put into neutral, raised engine and checked everything out, no warnings on Vesselview/smartcraft. Shifted into drive and reverse a few times, all fine. Then back into drive and began to throttle up again.... again BANG!! Immediately backed off again... and another round of checks...nothing. Back into drive... and throttled up no problem, and no issues, sounds(e.g. Grinding), the rest of day. But damn that didn't sound good... and has me concerned.
Boat is 2016 Hustler Talon 25, less than 30 hours(essentially brand new), Merc Racing 565, DTS, XR, ITS.
Merc Motor and drivetrain all still under warranty so I plan to make a call tomorrow... however I am a far cry from a mechanic, so figured I would check in here for any thoughts, wisdom or suggestions.
Thanks in advance mates.
I would make the call into the dealer or manu whom sold you the boat and complete engine package, also just saying on top of, if it was a different party whom rigged it. Should all still be under warranty. Also not many 565 out in the market place and especially less up here whom own a 565.
Is the bang noise -- drive side or engine side or hull side ?
how high was the drive trimmed?
Before doing any more damage, quit driving it immediately, and take it back for warranty ASAP.
A small problem, can become huge, in a very short time.
Get the problem documented as early as you can, to save yourself grief and major expense down the road.
Please let us know what they find, once the problem is corrected.
If it is a backfire, it could be as simple as bad gas / water in fuel / separators need changed. You have a warranty, use it. Lose FI wire harness connector will also cause a backfire as well as a loose plug wire.
