Propping 1994 Sr 271 Mag 496 ho >
Old 06-27-2017, 07:52 PM
do you have somebody you can borrow a 21 mirage from? you are at 480 WO now. the bravo 24 gonna put you down about 4600...
dereknkathy is offline
Old 06-28-2017, 05:01 AM
Thanks for all your help and information Indy, just out of curiosity how much did your Nordic weigh? My formula weighs 5250 pounds
Mjt 1969 is offline
Old 06-28-2017, 05:06 AM
Hi Derek, I originally started off with a mirage 21 and that prop was bringing me up to almost 5000 RPMs, so I borrowed a stainless steel Michigan wheel which was a 23 pitch that had really good push and mid range, at 4000 RPMs I was running right at 50 miles an hour but on the top end that Michigan will would only spin up to 4600 rpm's that's why I went with the Mirage 23 and I actually lost my mid range and also speed on the top end even though that wheel turned up to 4800 rpm's??
Mjt 1969 is offline
Old 06-28-2017, 05:12 AM
Hi Indy, thanks for all your help and information I appreciate it. Just out of curiosity how much did your Nordic weigh? My formula weighs 5250 pounds, just trying to compare The two as they have a very similar hull I just like to know what the weight difference is
Mjt 1969 is offline
Old 06-28-2017, 05:27 AM
Member #154
Indy's Avatar
I think around 4600-4700 according to brochure.
Indy is offline
Old 06-28-2017, 02:46 PM
I would try to find an old Mirage 23 or 25... non plus. Those older heavy V's with drives running deep seem to like the 3 blades. The older Mirage will likely spin better than the plus. I had a 242LS with big power and the four blades (especially Hydromotive Quad IV) just made the back end too loose.
chewymalone is offline
Old 06-28-2017, 03:15 PM
Knot 4 Me's Avatar
The '95 Indy Edition 271 i ran back in the day had a non-cupped regular Mirage prop on it.
Knot 4 Me is offline
Old 07-30-2017, 06:17 AM
Hi knot for me you had replied to a question I had a few months ago about propping my sr 271 w/496ho in it, you said you were spinning a non cupped mirage back in the day, what pitch was it and was it a plus or regular mirage? Thanks for any help still playing around with props
Mjt 1969 is offline
Old 07-30-2017, 12:31 PM
That boat is only going to run 60 with the power you have. The Bravo 22 will loose 2mph at the top but it's the best for economy cruise and getting on plane. You need another 100 ponies to make the 24p work.
ph1971 is offline
