-   -   Looking for suggestions on complete ignition system (https://www.offshoreonly.com/forums/general-boating-discussion/350600-looking-suggestions-complete-ignition-system.html)
Single cat 10-31-2017 03:34 PM
Looking to convert my boat over from the original Mercury Racing ignition. To a new style MSD set up complete. Does anybody sell a complete set up where I don't have to switch the harness over ? Thanks
Rookie 10-31-2017 09:43 PM
May I ask why? The MSD system has been less than reliable in the marine environment. Are you having issues with the Mercury ignition?
Single cat 11-01-2017 09:59 AM
Not having and problems with any of it. Was just assuming that the new msd stuff was better. The engines have the original Mercury Racing Distributors and stuff with msd coils. They are original to the boat from 1996 but of course have been rebuilt.
payuppsucker 11-01-2017 12:08 PM
I would steer clear of MSD, (Might Soon Die). My experience has not been good. The pro billet distributors are have serious corrosion issues. The new anodized versions may be better but I'm done with MSD. They wont even sell you a magnetic pickup, which is a bolt in piece. They want you to send the distributor back to them to have it replaced and they want half the price of a new distributor to do it. No thanks.
Cary 29 11-02-2017 07:18 AM
Try Daytona Sensors, excellent products
shunter2005 11-02-2017 09:22 AM
You might take a look at Davis Unified Ignition from Performance Distributors. Complete with built in coil - one wire hookup. You can even pick your own color cap. Also, take a look at their LiveWires if you are thinking of new plug wires.
Marine DUI Distributors - Performance Distributors Performance Distributors
BBYSTWY 11-02-2017 10:56 AM
Just ordered a set of livewires...thanks for the link!!
Tahoe540 11-02-2017 10:57 AM
I have both on my engine when I rebuilt it. Really easy with minimal wiring and they will do a custom curve for your motors/application at no cost, just call them. The wires are excellent as well.
shunter2005 11-02-2017 12:14 PM
Yep, that's what I did. Boat ran great with them.
If you want to install one, here is an easy way to connect up. Very easy. I found the two singles were easier to use.
https://www.amazon.com/Brand-Distrib.../dp/B00ARJOSZ2
endeavor1 11-03-2017 12:30 AM
Pulled the MSD, went with DUI, very happy camper. Havent seen hardly any corrosion issues. I used to clean the msd regularly and sprayed them with CRC inhibitor only to still find corrosion under the cap. Never had a box or coil fail like some have though.
Really like the livewire wire plug wires as well.
