Aluminum vs. Steel trailer
#31
What's the deal with people thinking those unsupported bunks aren't a failure waiting to happen? I saw a 30' center console Scarab with a engine bracket with double 250+hp outboards on a trailer with atleast 4' of bunk unsupported at the stern!! Add the bracket and the engines had to be 6' from the last support on the trailer. The bunks were the standard vertical 6" wide 2" thick standing vertically. I'm sure at some point they fail due to dealing with the heaviest end of the boat being unsupported.
#32
I used my New Trailer from Ace Trailer this entire season. I have had 8 Steel trailers and 3 Aluminum Trailers. for Various Boats I was very happy with it. The Support goes all the way to the back as you can see in the pictures. Boat loads great and self centers. Good Support for the Steps. Kodiak EOH brakes work great and it looks good under the Bunny Lounge.
"Bunny Lounge" gets new Trailer
#33
I've owned 4 different steel trailers that were fresh water only and stored inside. Had to deal with rust on all of them. If I ever buy another new trailer it will be aluminum.
#35
Myco trailers are awesome, we currently own 4 of them and have not had any issues. They have gotten to be extremely expensive lately though. I just had them quote a new trailer for a boat we are getting and had Manning and Broward quote apples to apples options. Myco was about $13k higher than Manning and $7k more than Broward.
#36
#37
#40
had numerous trailers over the years,,steel ,,aluminum,bunks ,,rollers,, c channel,,box tubing ,leaf spring,,torsion's,etc,as long as the trailer is set up right for the boat and the weight rating is correct they will all do the same job,,it just comes down to preference,
I keep reading about I beam Aluminum trailers (some call them Florida trailers) and how some here thing they are crap,,not sure thats the case.
a lot of reply's with people saying how the rear of the boat is not supported ,,that is false! sure the boat is supported its sitting on two 4x10 wood bunks,yes I know some of the 4x10s is sticking out past the rear cross member usually 18-24" ,but the 4x10s are 12' to 16' feet long depending on the size of the trailer,and those 4x10s are not flexing so no worries there,(kind like a balcony is supported on a building)
some say aluminum flexes ,sure it does but a 35' foot steel trailer will flex as well,not as much as aluminum but a long enough steel trailer will flex as well,ever stand on a steel bridge?sure does flex.
I personally thing a aluminum correctly set up trailer with 4x10 bunks will support the hull better than the custom expensive steel trailers,like I said earlier the 4x10s do not flex try pushing on one and you wont be able to move it,,but on steel trailers most manufactures use 2x6 bunks, that causes pressure points on the hull of a boat,your boat is actually only supported only were the bunk brackets are,anywhere in between the bunk brackets you can push that 2x6 up and down,
so what ever trailer you go with just remember ,,1 to maintain it,,and 2 is to use safety straps..and no reason to put a $20k trailer under a $40k boat.
