-   -   Black hull side, maintanance nightmare? (https://www.offshoreonly.com/forums/general-boating-discussion/351490-black-hull-side-maintanance-nightmare.html)
happy hours 12-27-2017 06:46 AM
I am in the market for a 23-24 CC for cursing and some nearshore fishing. I Found a decent deal on a used boat (seahunt, triton 24) but it has black hull sides from run rail down. It clean and polished but since it will be used 100% in Florida sun I worry the black will require more waxing and maintenance then I am used to. (Always had boats white with accents only). I am use it more than polish on the weekend type guy and put about 200hrs a year on a boat. Anyone ever have a dark color boat, any thoughts?
Interceptor 12-27-2017 09:32 AM
Unless the boat is kept out of the sun and overly maintained the red, blue and black hulls all look sorta chalky by seasons ends. The white hulls are the same but the oxidation doesn't show as much.
COOPS 12-27-2017 10:32 AM
Mine is a 292 formula and the black is Imron, not gell. It is very easy to keep up with. It just needs to be wiped down after every use with a spray wax.
Too Stroked 12-27-2017 04:42 PM
Black is an absolute maintenance nightmare - and even worse if you're in Florida. If the color is in the gelcoat, it will generally oxidize within a year or two - even if you keep after it. If the color is done in paint, it'll last a bit longer. And that's not even mentioning the somewhat more manageable issues of hard or salt water stains that will show like crazy. I'd be willing to bet that if the boat you looked at is used, it was carefully buffed out by the dealer already. And remember, once gelcoat has oxidized, you'll be buffing it constantly just to keep it looking acceptable. On the plus side, your boat will weigh less every year though!
Powerquest230 12-27-2017 06:45 PM
Back around 1990 we owned an early 80’s Baja that was all black- at 10 plus years old the topside and deck were a SOB but the sides were pretty easy to keep up. I see a lot of black and navy sided Cobault, Formula, and Proline running around the Tampa Bay Area that look good.
rak rua 12-27-2017 07:25 PM
My 34 Fountain had black hullsides. Never had a problem BUT it was lightly used and kept indoors.
Keep one indoors I'd think no problems. If it sits outside, lots of polish!
RR
wananewboat 12-27-2017 08:36 PM
Be sure to buy a black Sharpie marker to keep on the boat also.
beertruck 12-27-2017 09:29 PM
last three boats have been all black. started with black gel, then custom painted black with flames. never had a issue with mine, and would do it again.
seafordguy 12-28-2017 07:23 AM
If my red SeaDoo is any indicator I would look for another boat. That thing can fade under a cover.
thirdchildhood 12-28-2017 07:36 AM
My Hydrostream was black and you could literally fry eggs on it even in Michigan sun! Seats were gray and I had to cool them with water before sitting on them. No good!
