Gas Tank Vent Leak Gas Down Side of Boat. fix? >
Old 02-09-2018, 06:48 PM
I would simply put less gas in the boat unless I was to use the fuel immediately. I had this problem all the time in a boat I use to own and found that was the easiest and safest thing to do. If I was gonna use it and needed it I would buy the gas just minutes before going on my trip.
iroc fan is offline
Old 02-10-2018, 05:50 AM
We started using this stuff last year and it buffed the gas stains out. This is some good shizit.
Attached Thumbnails Gas Tank Vent Leak Gas Down Side of Boat. fix?-9ebdd89f-a924-4909-a24f-c523fe3766fe.png
SecondWind is offline
Old 02-10-2018, 06:01 AM
I just built a new 2018 Statement and to my amazement it came with new "drip less" over flows. They over flow/vent back into the top of fuel fill hole so no gas runs down the side of my boat or gets into the water. Its a great idea!!!
I think they even told me they are coast guard required. Don't quote me on that though.
Drinking Fountain is offline
Old 02-10-2018, 06:44 AM
Rob
Strip Poker 388's Avatar
Im not getting stains,ive seen it stain gelcoat before ,I tried Klasse that puts a acrylic coat on and its not gas proof
Attached Thumbnails Gas Tank Vent Leak Gas Down Side of Boat. fix?-autogeek_2268_214528288.jpg
Strip Poker 388 is offline
Old 02-10-2018, 06:52 AM
What about adding a "T" in the vent hose up close to the vent and sending a slightly larger (CG Approved fuel line) line back to the tank "T" into the vent line fitting at the tank? I'm theorizing it would act like an expansion tank. Also, keep in mind that your vent line should be secured higher than the vent itself so this T should obviously be a couple of inches below the vent.
TomR is offline
Old 02-10-2018, 06:59 AM
Rob
Sound cool, could u take a pick of that set up?
I guess ya could T into the fill neck but still needs to be vented
Rob
Old 02-10-2018, 07:21 AM
Rob
Heres a pick of the fill hose, the vent line route's with it, out the side, i can make it go higher then go over to side,
Also heres a pick of the #12 water dump for the Whipple, I could use the empty dump port,epoxy in a screen. throwing around ideas
Problem when putting gas in hard tell how close to full ya getting, gauge can be off 20-30 gallons,its not exact on, use to be able to hear it gurgle when close to full, I only fill it up when going outa town,thats fueling on the trailer. locall its sits on a lift and I just buy alittle fuel to just run around our 5 mile wide lake but I have ran out of gas 200 gallons in 1 day out in the gulf.
Rob
Attached Thumbnails Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8372.jpg   Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8373.jpg   Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8374.jpg
Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8377.jpg   Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8376.jpg   Gas Tank Vent Leak Gas Down Side of Boat. fix?-img_8375.jpg
Old 02-10-2018, 03:39 PM
Trust me I would love too!!! That would mean I was down in Florida boating right now and not sitting in snowy Michigan!!!! LOL
Old 02-11-2018, 04:07 PM
A negative edge fuel ring was offered in the late 2000's. They were designed to fit around the flush style fuel tank vents. Lewis Marine supply carried them a number of years ago, believe Whitecap manufactured them.
oceanoutlaw is offline
Old 02-11-2018, 08:35 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Someone makes a thru hull fitting for use with AC that might be what you are looking for. Its a standard thru hull, but with a small lip on the bottom of the hole that extends out just a bit. Its used to stop the water stains on the hull sides from when the AC is running and there is that small trickle of water constantly running down the side.
Been looking for manufacture, but no luck. Its pretty much same concept as SilverCat put up
US1 Fountain is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
