Gas Tank Vent Leak Gas Down Side of Boat. fix? >
Old 02-12-2018, 08:59 AM
Originally Posted by US1 Fountain View Post
Someone makes a thru hull fitting for use with AC that might be what you are looking for. Its a standard thru hull, but with a small lip on the bottom of the hole that extends out just a bit. Its used to stop the water stains on the hull sides from when the AC is running and there is that small trickle of water constantly running down the side.
Been looking for manufacture, but no luck. Its pretty much same concept as SilverCat put up
Groco advertises their flush mount through hull is dripless when installed protruding out of the hull. Is this what you're looking for?
https://www.groco.net/products/fitti...es-flush-mount
BradH is offline
Old 02-12-2018, 01:24 PM
BUP
I sell and mounted the 90 degree flush fuel vents where access allows it to mount at 11 or 12 or 1 oclock positions that has seemed to help with some vented fuel spills. In the link below the 90 degree fitting
https://www.westmarine.com/buy/attwood--flush-mount-316-stainless-fuel-vent-straight-vent--P006_187_003_530?pCode=10017846&cm_mmc=PS-_-Google-_-GSC%2520-%2520Product%2520Type-_-10017846&product_id=10017846&adpos=1o4&creative=10 8421551724&device=c&matchtype=&network=g&mrkgadid= 3076579434&mrkgcl=481&rkg_id=h-36a3d4c8073812f63672a65cb0ac29c2_t-1518463227&gclid=EAIaIQobChMIic2lpIyh2QIVRLXACh2pr QJxEAQYBCABEgInGfD_BwE
BUP is offline
Old 02-12-2018, 01:25 PM
BUP
better quote just in case links still do not show up here.
BUP is offline
Old 02-12-2018, 02:59 PM
Plum_Crazy's Avatar
Have you looked at the Racor Lifeguard LG100?
RSL0184%20Racor%20Lifeguard%20Fuel-Air%20Separators.pdf
Plum_Crazy is offline
Old 02-13-2018, 05:06 PM
I haven't tried it but I'm betting an inexpensive inline fuel filter will solve your problem. Vapors will pass and liquid will collect and drain back into the tank.
payuppsucker is offline
Old 02-13-2018, 11:51 PM
BUP
Attachment 575156
forgot about these in the link - the LG 50 is good and smaller to install and is for gas only. The LG 100 can be used for diesel or gas. The only problem with either is technically can not be mounted more than a 45 degree angle. Vertical mount is the best way to mount the Racor LG 50 or the LG 100. They are listed in the Parker / Racor Marine filtration systems catalog.
BUP is offline
Old 02-14-2018, 10:38 AM
Chevy-Harley fan
gmhdfan's Avatar
BUP clean out your email, its full. Need to talk to you about something.
Thanks, Pete
Pete
gmhdfan is offline
Old 02-14-2018, 01:16 PM
BUP
Sorry about that. PM clear for now.
BUP is offline
Old 02-19-2018, 01:32 PM
Rob
Strip Poker 388's Avatar
The attwood says it recomemnds a In-Line Surge Protector w/ the vent, that it doesent prevent nsplash backs, not my main problem too,so im betting it want prevent fuel from seaping out when over filled and gas swelling from heat making it come out.
Im thinking that when its full and the gas swells in the tank it will still push gas out the vent even w/ it being 2 feet above the gas level,or even a loop, but the fuel filter catch might work, but it might restrick flow of air when filling, or when the filter would have gas in it and keep it from breathing?
attwood
Flush Mount Stainless Steel Fuel Vents : Attwood Marine
allow for a 4" (100mm) minimum anti-siphon loop above the ven
paper works asys
This fuel vent does not prevent fuel line surges. It is recommended that you install an inline Surge Protector (Attwood No. 1675) between the vent and fuel tank
Attached Thumbnails Gas Tank Vent Leak Gas Down Side of Boat. fix?-zz-att.jpg   Gas Tank Vent Leak Gas Down Side of Boat. fix?-zzzd.jpg
Strip Poker 388 is offline
Old 02-19-2018, 02:20 PM
Revd Up's Avatar
I pulled out my vent catch can set up yesterday and installed the Lifeguard LG -50 .
Hopefully that will do the trick.
Thanks for the recommendation!
Revd Up is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
