-   -   Removing 450 pounds from transom. (https://www.offshoreonly.com/forums/general-boating-discussion/352258-removing-450-pounds-transom.html)
Single cat 02-11-2018 02:32 PM
Doing a engine swap in our boat from super charged intercooled engines over to NA engines. I know we have lost some were around 450 pounds or so. Just wondering how much more transom lift the boat is going to have being 450 lighter. The boat is a 32 ft Skater
mikebrls 02-11-2018 02:58 PM
whats the ride difference between 2 or 3 in the back seat compared to an empty seat ?
Single cat 02-11-2018 03:05 PM
Ride
Never had 450 in the back seat with the set up we have know.
phragle 02-11-2018 03:22 PM
Well then, find a fat chick and go for a boat ride,,,,,,,
Tinkerer 02-11-2018 04:07 PM
If the HP and torque are going to be roughly the same it should make the boat ride a lot flatter and faster. You may even be able to drop a blade off the props thus being more efficient.
Single cat 02-11-2018 07:10 PM
I was thinking a long the same lines. I was just mainly wondering about Stern lift
Cash Bar 02-11-2018 07:30 PM
4 Attachment(s)
We took my big-power PSI motors out last summer and went to Merc 700s. With the rigging swap, and losing the oil tanks and unnecessary crap, we dropped over 650 lbs. Took my CG from the bilge wall to the center of the cockpit. It's amazing. Only adjustment besides prop size was the water pickups needed to drop a notch.
It's a widened 32' Skater as well. And she runs and flies perfectly level now.
phragle 02-11-2018 08:07 PM
Im guessing by the name its a cat?? You could rnd up porpoising, but remember, Its a lot easier to add weight than it is to take weight out.
Tinkerer 02-11-2018 08:14 PM
One less blade will help lessen transom lift.
Tinkerer 02-11-2018 08:26 PM
I tried a stock 26 Maximus 5 blade and it turned my 26 into a three point hydro. Rode on the nose and prop. Top speed was 95 instead of 107 at 6100 rpm with a stock Bravo 28.
When I let off the gas the boat just about stood on it;s nose. Everything flew forward including everything that was inside the cooler. I about hit the steering wheel. It was like slamming on the breaks at highway speed.
With a four blade I don't get any of this. Top speed so far is 112 at 6100 with a labbed 28 Bravo from BBlades.
Need to order a 26 OR add more HP ( thinking about what to do )
Considering going to 14.5 to 1 and E85
