-   -   OT - How to remove painted lettering from truck door? (https://www.offshoreonly.com/forums/general-boating-discussion/35239-ot-how-remove-painted-lettering-truck-door.html)
JON242 10-21-2002 08:30 AM
I just bought a used Dodge truck from a guy that had his company name painted on the doors. What is the best way to remove it without damagingmthe paint? A guy told me to use Easy Off oven cleaner but I would think anything that would take the lettering off would also take the paint off. Anybody have any experience with this?
Wardey 10-21-2002 08:40 AM
Try Easy Off Oven Cleaner. This works 90% of the time. Wardey
Team V 10-21-2002 09:27 AM
The company I work for used to use easy off to take blue painted lettering off white painted trucks, pretty ugly... took off the paint but dulled the white paint real bad.
Flyinbrian 10-21-2002 10:01 AM
I am no paint and body guy, but I have removed painted letters from gel coat by wet sanding with 1500 or so, then buff it out.
I am no expert on clear coats, but I hate the sound of using harsh chemicals for cleaning ovens on my truck's finish. Maybe wetsand with some 1500 or 2000 and buff?
Where's a paint guy when you need him????!?!!?
Semper Fi 10-21-2002 12:24 PM
Easy off oven cleaner will take off the lettering and not harm the paint. Iv'e done it a few times!!
Chart 10-21-2002 12:28 PM
This is second hand info, I've not done it personally. Use a small paint brush or q-tip to apply the easy off to the lettering only. Don't let it sit very long either. Trick is to get the letters off without letting the easy-off get on the other paint.
NJScarab 10-21-2002 12:30 PM
Go to your local auto paint store and get a 3M take off wheel. It's a soft multy layer disk you hook up to your drill. Takes off the paint and won't harm your finish.
Qst4IT 10-21-2002 01:13 PM
Yup oven cleaner & A light buffing afterwards works like a charm. My old mans done it on his trucks for years. Spray it wait a few min. & then a good wiping, may need to give it two shots like that depending on the paint used for the lettering.
Ken
SABER28 10-21-2002 02:24 PM
try your wife fingernail polish remover or acetone (same thing) a little on a rag and rub gently, it can take a while.
BTW ,i'm a bodyman , i know this works!!!
