-   -   outdrive clicking noise (intermittent) (https://www.offshoreonly.com/forums/general-boating-discussion/355355-outdrive-clicking-noise-intermittent.html)
sashap 07-15-2018 08:10 PM
Sometimes when I slow down from high speed or speed up from idle, I hear a weird bumping clicking noise that sounds like outdrive but not sure. It's almost like the sound made when slowing down from high speed and engine goes to idle but prop is spinning from moving through water fast. The difference is that when the noise starts, it usually will do it forward, reverse or right through neutral. I can't pin it down. It is not always either. I can stop for a few seconds or restart and the noise goes away. If I just try to run through it, there is a vibration I can feel in the boat. Ideas?
Speedracer29 07-17-2018 07:04 AM
What engine and drive combination? Assuming it’s a sterndrive, when was the last time the gimble bearing was checked/aligned?
sashap 07-17-2018 10:50 AM
last week.
JIMKID Motorsports 07-17-2018 12:38 PM
get rid of the mitten just kidding
sashap 07-17-2018 01:23 PM
sorry, 3.0 mercruiser Alpha one phase2
Nuke427 07-17-2018 04:35 PM
Last time I heard a click or knock coming from an outdrive, it blew a bearing out the side a short time later. Any different noise is not good. This was on a 350 mag, bravo 1 boat.
sashap 07-17-2018 05:34 PM
I can’t confirm where the noise is from. It’s almost like the sound of a slipping dog but can’t be sure. Could it be the connector to the engine?
sashap 07-17-2018 05:35 PM
It’s also very intermittent and I can’t pin down what sets it off
JIMKID Motorsports 07-18-2018 05:44 AM
put it in gear and trim it up if it gets worse could be the gimble bearing goood luck
TYPHOON 07-18-2018 02:10 PM
Open the motor hatch and have someone else drive to confirm its not in the motor compartment.
