Looking for a good 2001 6.2 bare block
casting number is 10243880 needs to be original to swap original pistons and the rest to replace a cracked block... anyone have that? Cant even order a new one from merc thanks |
will have to look at the casting numbers of my block to be sure.
Originally Posted by jeff32
(Post 4641337)
casting number is 10243880 needs to be original to swap original pistons and the rest to replace a cracked block... anyone have that? Cant even order a new one from merc thanks Most stroker cranks require a little clearancing on the block, but your machinist will.should know this. Speaking of which, this block is super common....your engine guy may even have one. If not, sure as schit he can/will get one for you. |
He does not think heads would fit the block... will see, thanks |
Sutphen did you have a chance to look? |
(Post 4641748)
880 block and standard vortec heads. Look up the part numbers. Same as 5.7.
just as said above...that number is coming up as a 5.7
Search Results for '10243880' - Casting Numbers .info: engine blocks, heads, and more they are a dime a dozen from all the trucks that used them from 95-99 |
| All times are GMT -5. The time now is 06:59 PM. |
