-   -   Engine hatch hinge replacement? (https://www.offshoreonly.com/forums/general-boating-discussion/356652-engine-hatch-hinge-replacement.html)
ancho 09-13-2018 05:35 PM
I have a 1991 Cigarette Cafe Racer. I need new engine hatch hinges. Does anyone recognize these or know of a source where I could get new ones?
https://cimg0.ibsrv.net/gimg/www.off...efc0921092.jpg
sr73z 09-13-2018 08:08 PM
www.perko.com search hinges
ancho 09-13-2018 09:47 PM
only found like 5-6 different models but none that match.
1MOSES1 09-14-2018 08:02 AM
Try lipship..
BUP 09-14-2018 09:29 AM
Sea dog
Attwood
or if I come across something else.
Ed 09-14-2018 07:06 PM
Any good chrome shop can strip those & replate them, and get them back to you in a weeks time. They are brass hinges. Been there.
ancho 09-15-2018 09:36 AM
One of them is slightly bent - so that doesn't solve the functional problem, only the cosmetic one... I might try to bend it back into being flat/true, but I don't have high hopes for that.
US1 Fountain 09-17-2018 10:36 AM
A buddy has same boat Ď91 cafe carbon fiber and replaced his hinges a couple weeks ago. His were Gem (Gemlux) brand. But his were the more traditional square style with 6 screw holes. Not sure why the same boat has different hinges. A quick search didnít yield any like yours on Gem site. Might shoot Gemlux a pic and see if they made those.
Southco also has a large selection of marine hinges. Might have one with same bolt pattern?
If yours are just bent on the flat area, a machine shop can flatten them out in a hyd press. Iíve also used our machine vices to flatten bent steel as the vice jaws are ground smooth and wonít mare the finish.
ancho 09-17-2018 10:45 AM
Interesting info.
Mine are just bent in the flat area - one side only - so maybe I will try the machine shop...
I found some Sea Dog hinges that look nice - but it would require mounting 2 per side vs one per side to deliver the same surface area of holding on the fiberglass.
Thanks!
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
