-   -   just blew-up an engine... (https://www.offshoreonly.com/forums/general-boating-discussion/35694-just-blew-up-engine.html)
timucin 10-27-2002 05:35 PM
one hour 3000rpm = boom!
was testing/cruising a friends boat with his new 383cu.after an hour a metal sound started to come from the engine(I am familiar with that sound cuming from the bearings like tarrrrrrrrrr!) but I was far from the shore; tried to reach the shore around 1000-1500 rpm but engine died with the expected sound 'DANK!'....
-how many of you are familiar with that ugly bearing sound?!?
-how often you brake engine?
the worst thing ; he is not going to believe me ;I was cruising with 3000rpm...I wouldnt believe in such a position ..would you ?
HighPriority 10-27-2002 06:07 PM
Sorry to hear about your engine proplems. We have been there and done that. We had a new engine blow up due to the oil pump, with only about 15 mins runnig time, and olny 2 days before leaving for our 1st race this year. We had to pull a couple all nighters to just get it fixed and did not start the motor till we got to Marathon Fl. We did our break in on the pace lap.
Warren
High Priority Offshore
spyguy 10-27-2002 07:24 PM
I have Brand New engines we were going to run this year if interested.........
407 Small Block Chevy
540 Ft. Lbs.Torque
645 Horsepower
timucin 10-27-2002 09:08 PM
spyguy: I hope I wont have to buy a complete engine for him.we will see in this week.
by the way visited your web-site you have cool stuff..
jpclear 10-28-2002 07:37 AM
When that happened to me (at under 4000-same sound & result you describe) it was the head of an ex. valve stuck in the top of a piston. Even if that's not it but you are running anything less than inconel quality grade exhaust valves, upgrade when you have it down!!
DanL 10-28-2002 08:03 AM
make sure you didn't detonate it from too much compression. These stroked small blocks are never built with dished pistons. The cylinder heads have very tight combustion chambers and never can't be opened up too much.
Wally 10-28-2002 08:09 AM
Nastiest sound i've ever personaly heard was about two years ago when i was cruising around 3500rpm on my way to the air/water show here. With absolutly no warning at all....the engine spit a rod and psiton right out the oil pan!!! Filled the whole cockpit with smoke from the oil spweing everywhere!! Scared the crap out of me! i thought i hit a big log or something and was taking on water!!! :eek: Weirdest thing was the engine would still start and run normally like there was nothing wrong!
Mike J 10-28-2002 08:15 AM
Had the same thing happen
to one of 2 NEW Blown 502s
Main bearings were to did
not have enough clearence
OHH I rented a movie that
was filmed or had a lot of
background done in your
City, Istanbul, Turkey.
Movie is "The Accidental
Spy" With Jackie Chan.
Some Boats but NO Skaters Mike J.
