Which Rinda/Diacom connector for the indmar SN?
Hi- need to know what cable I need for this model? MEFI4 or 5? I wd think 4but it has the silver ECM with 3 plugs attached-
7INDM05.7CAT 5.7L MODEL: 057676 ENGINE: 129399 MFG DATE: 06/28/2006 |
MEFI 4 s all of those were black cased and 2 front J connectors. Silver was MEFI V for those years and E Controls was a tad later depending on engine serial numbers. . Indmar only used Mefi and E controls. I take it your engine is Emission controled with catalyst and O 2 sensor exhaust ?? would that be correct
MEFI V thru VII are silver cased. MEFI 1 thru 4 all are black cased |
bup thanks - yes i believe it has the CAT. I see rinda lists the 94029 connection for CAT systems- so do I need the 9027 or 94029?
Indmar: • 1992 - Up EFI engines: 1992 - 2007 (GM MEFI-1 thru MEFI-4) Adapter #94005 2007-2008 (GM MEFI-5) Adapter #94027 (will NOT work with PRO) 2008 - Up (CAN Network adapter for all catalyst equipped engines, also used on many manufacturer's 2008-up engines) Adapter #94029 2008-Up (Indmar ECM) Adapter #94027 (will NOT work with PRO) 2008 - Up (CAN Network adapter for all catalyst equipped engines, also used on many manufacturer's 2008-up engines) Adapter #94029 |
the 94029 adapter is for CAN and yes all the CAT engines have this as well.
I do have one extra brand new CAN adapter rinda / Diacom 94029 I can sell for $ 200 This cable thru Rinda / Diacom is $249 plus shipping and is listed on their website. . Let me know ASAP before I sell it. thanks |
what is CAN? sorry- canadian model or the CAN system on the boat? And can i use the NON CAT cable on a cat system, will it make a difference? Sorry-still trying to get to grips with all the acronyms..
CAN systems - marine apps.
CAN aka CAN Bus = Controller Area Network NMEA 2000 |
HI
Do you still have the extra 94029 adapter? |
Originally Posted by BUP
(Post 4667215)
I do have one extra brand new CAN adapter rinda / Diacom 94029 I can sell for $ 200 This cable thru Rinda / Diacom is $249 plus shipping and is listed on their website. . Let me know ASAP before I sell it. thanks Do you still have the extra 94029 adapter? |
| All times are GMT -5. The time now is 08:26 PM. |
