-   -   Hp6a filter too long (https://www.offshoreonly.com/forums/general-boating-discussion/359961-hp6a-filter-too-long.html)
phragle 04-05-2019 12:36 PM
does anyone have a cross reference to shorter filter ???
Drock78 04-05-2019 01:03 PM
First problem is that it's a Fram..lol.
SB 04-05-2019 01:48 PM
Maybe Wix 57521 ?????
????? means i quickly looked this up. It's your motor, so double/triple check. :)
HP6A specs/dimensions : FRAM HIGH PERFORMANCE High Performance Spin-on Oil Filter HP6A FRAM
Wix filter look up via specs/dimensions: Catalogs
frickstyle 04-05-2019 06:20 PM
Rob, I have some nice horizontal remote mounts I would sell you, then length would not be an issue. Has the nice bracket with engine lift points. Let me know if you're interested.
phragle 04-05-2019 07:32 PM
Now that its in the boat, I think if I trim the spacers holding the bracket off the head a bit, it will fit.......
Dean Ferry 04-08-2019 07:52 AM
P,
I have the same issue on the Talon's 572, I have to run the Merc Racing filter 35-88112K01....
Hope that helps...
frickstyle 04-09-2019 09:29 AM
Bu then what, pull the engine to change the oil???...
F-2 Speedy 04-09-2019 09:56 AM
Is there a long filter with the anti drain back provision ??
phragle 04-09-2019 10:19 AM
Then I should be able to get filters on and off easily.
phragle 04-11-2019 05:56 PM
Spent 5 minutes on the lathe and made shorter spacers... now it not only fihttps://cimg2.ibsrv.net/gimg/www.off...94b3f1c67a.jpg
ts, but also easily goes on and off....
