-   -   Leakdown Test Results (https://www.offshoreonly.com/forums/general-boating-discussion/360799-leakdown-test-results.html)
Holy Smokes 05-24-2019 10:54 AM
Originally Posted by onesickpantera (Post 4688300)
And was the engine warmed up before doing the leak down? All it takes is a tiny piece of carbon on the valve.
Not certain.
BUP 05-24-2019 11:41 AM
describe your testing procedures in full details and what leakdown tool are you using , a good quality tester and in good condition ? And are you sure you are at TDC all the time ??
Like another post mentioned do a compression test and you can always do a running compression test as well and intake vacuum testing
also what is the MAP pressure reading thru out all the running rpms ??
