GIL sbc exhaust?
Can anyone tell me about the old GIL sbc aluminum exhaust manifolds with stainless risers? Were they a decent design? I have a chance to pick up a new in the box set from a local guy. The risers are not a long tube design but appear to be a direct stock replacement.
Gains will be very minimal if at all on a SBC.
I agree with Griff. Been there done that.
They have to be better than my stock log exhaust... https://cimg8.ibsrv.net/gimg/www.off...e09f64873.jpeg |
Nope. About 80lb's lighter though...all said and done.
What did they do to that poor riser ? BTW: What are you attaching these too (ie: what motor), maybe we can help. |
https://cimg8.ibsrv.net/gimg/www.off...8e423c8efb.jpg
mine worked good but were dry to the tip |
If you have the old log exhaust then I would switch to the Gils simply because of the age of yours.
If you had the Merc cast iron center rise exhaust, then I would leave them. I still doubt you will gain anything performance wise. |
These will be replacing the aging old stock log manifolds, that's the main reason for the swap. These GIL's will cost me less than a new Merc cast iron center rise setup. The engine was built from a Quicksilver reman long block for the previous owner. Quicksilver part#: 87971R5 Bore is listed as - 040 on the tag so I think that's a 358? Its all stock except for the Edelbrock Performer EPS intake (Part # 2701) and the Edelbrock Marine Series 600 cfm, Square-Flange, Electric Choke Carburetor, non-EGR (Part # 1409). I just have been enjoying it as is for the last few years since I picked it up.
https://cimg6.ibsrv.net/gimg/www.off...c9a356b008.jpg |
FYI: The new wet joint Mercruiser center rise exhaust kit can be had for near/under $700, but they are cast wrong and can/probably will leak. The new replacement from merc won;t be out for a month. Hopefully those are cast right.
