Flapper took a chit.
Fired up the fresh 525's yesterday and one spit the internal flapper in the exhaust tip out on the ground. I have the F'n thing, question is can it be put back in?
Could one weld it back in? Is it welded in in the first place? Teague has a replacement flapper that claims no welding required, anyone ever have to deal with this? |
I had one pop out of a stainless Marine tip. It was an old design and there was an updated one available so I ordered a set and had my guy weeks them in. Worked like a charm.
I haven't messed with the non welded ones. |
Fapper??? what kind of websites have you been surfing???
I believe the rubber flapper is bolted by 2 bolts and a small retention plate at the top.. Check CP performance. |
Originally Posted by phragle
(Post 4695301)
My bad. Mean the FLAPPER. |
Originally Posted by SUPERSTITIOUS
(Post 4695303)
2 Attachment(s)
Could be Stainless Marine internal flappers?
Originally Posted by SFOcean
(Post 4695558)
Picked the boat up yesterday from my engine guy, so now that I have it back I can look into the fix. Thanks for the post, I have looked at the CMI site but have not seen that. Is that a slip in replacement unit? Mine is made right into the tailpipe. |
Im not a big fan of the clamshell type. Once one starts to break you'll notice that you start having problems with the rest. If you havent realized, they make a lot of noise any way.
Clip, clop, clip clop, clip clop clippity, clop. Just buy new tips. |
"Thanks for the post, I have looked at the CMI site but have not seen that. Is that a slip in replacement unit? Mine is made right into the tailpipe."
The photo is of a slip-in. Stainless Marine makes various versions of the one-way. They are not quiet however the bonded 'rubber' coating around the edges mitigates the noise. I have one set that were made in 2001, still work fine. I needed internal as I have Shotgun 1 tips also. On yet another boat, we just added the newer design Hardin Marine rubber flapper tips, work well after a bit of trimming. Will be super easy to repair if necessary. |
