-   -   Just the facts.... (https://www.offshoreonly.com/forums/general-boating-discussion/364468-just-facts.html)
Bostonirish 01-06-2020 11:43 AM
Originally Posted by Unlimited jd (Post 4720799)
the carbon boats are stiffer, I don’t notice a big difference in just the epoxy. But that’s just me.
there will be more flex in a vinylester laid up boat I doubt there’s much difference between epoxy and carbon
Unlimited jd 01-06-2020 02:47 PM
Epoxy is the resin, carbon is the laminate. Carbon would be in addition to or instead of e glass, s glass etc, epoxy would replace the vinylester. My boat is epoxy, carbon deck.
my buddies 42 is epoxy, all (mostly) carbon and it is noticeably stiffer
offshoredrillin 01-06-2020 03:31 PM
Originally Posted by AngryandDeranged (Post 4720646)
Fellow boating enthusiasts,
After a 12 year absence (its amazing how life gets in the way of having fun) I am doing my homework to purchase my next go fast. Previously I owned a ‘00 32’ Sunsation and the only complaint I had was the sun pad was to small. I have always admired Cigarettes (TG), Fountains (light and EX) and Outerlimits (Quattro and legacy) which I am looking at either a 38’ or 42’ in said models.
I am hoping to hear the pro’s and con’s of cabin head room, ride/performance, amenities etc...no detail to small. I could answer my own question if I had all 3 makes sitting in the water and test drives were an option. I am assuming 2x 525’s or better for power. I am asking for your knowledge and opinions. I thank you in advance and it feels good to be back on Offshore Only!
My 42 Tiger might be available.. whole thread on it in the cig section.. just had something pop up that may make me want to move up.
apex svt 01-06-2020 06:52 PM
Got a few notes on the Quattro from when we were looking at them;
04-08 28 made, 4 with a finished v-berth.
600’s run 101mph
700’s 108-110mph Bravos get loose, nxt’s run much smoother.
-From Dan at OL
Heard through the grape vine the blue one with flames, with 600’s gets really loose above 90ish mph. Which is a bravo boat.
Interceptor 01-06-2020 06:57 PM
Whatever one you decide on put a moisture meter and mallet to the hull. Lots of talk regarding build quality but water always wins. Check the thread Division1 has in the cigarette section.
frickstyle 01-07-2020 06:58 AM
Some worthwhile feedback I did receive (more knowledgeable OL people can correct me), Re: the 42ft models - pre-2004 Legacy; wood transom construction = better riding and handling rough waters (Due to a heavier layup?). After 2004 mostly all composite, probably lighter and may not necessarily ride or handle rougher water as well. As far as general handling (top end stability, turning, etc) I have no idea but I assume that's more up to the bottom design which I have very little knowledge of.
I'm just trying to learn here through this thread. Would be nice if the real knowledgeable people would chime in here (owners, dealers, builders, etc), but I understand if they don't.
Some feedback from a few that have ridden in the OL and owned other high end models, comments similar to they handle much like a Hustler, chine walking and questionable top end stability (is that more of a setup issue? People messing with higher drive positioning trying to squeeze out 2-3 mph, props, etc?). I find that hard to swallow as almost all models run over 100mph.... May be attributed to the light but strong layups using the new laminate tech/schedule?
I'm a big fan of the OL models, I would like to have some more understanding of which models/years excel at rougher water stability and handling.
Unlimited jd 01-07-2020 07:53 AM
600’s run 101mph
-From Dan at OL
who was running it? I’ve been 96 in mine no issues. I will say I trim up before going full throttle not the other way around. Combats transom lift
Unlimited jd 01-07-2020 07:55 AM
some of it is setup, and late 04 or 05 starting with Paul’s triple 525 they made some step changes that changed the low speed handling for the better, top end seems the same.
ALL_IN! 01-07-2020 08:03 AM
Nobody talking about Fountains yet??? :poopoo:
rak rua 01-07-2020 09:09 AM
I was wondering myself......
Theres a couple of nice looking 42's in the classifieds at the moment
https://www.offshoreonly.com/classif...es-o76763.html
https://www.offshoreonly.com/classif...ng-o76791.html
