-   -   03 Formula 292 Prop help (https://www.offshoreonly.com/forums/general-boating-discussion/366413-03-formula-292-prop-help.html)
02Formula33ss 05-18-2020 05:11 PM
Just bought a new to me 292 with 350 Mags w/ 250hrs.
Got to run the boat today and wasn’t impressed. With a 1/2 tank and just myself I was only able to hit 63mph @ 4950 RPM’s with 28P Bravo 1
Are these the right props? It also slips a lot getting on plane.
1MOSES1 05-18-2020 05:59 PM
We ran 28’s for a while with 383’s in a 2003 292...in my opinion they were too much prop. Assuming you have 350’s and not the 6.2L’s you are probably over propped. I’d try a 4 blade 26. Should be easier to get on plane, and get the Rpm’s up a bit.
02Formula33ss 05-18-2020 06:41 PM
Thanks, From what I’ve read it should at least hit 70?
F14A water jet 05-18-2020 07:53 PM
Outdrive trim is critical. On my 311 twin, motors tucked way in for hole-shot, level (measured/confirmed with a straight edge) for cruise (once on plane), and way out (slowly to avoid weight shift porpoising) for max speed. There is over 10 mph difference between level and trimmed out.
Bigsbetter 05-18-2020 07:53 PM
I just bought a set of Mercury REV4 25 pitch to test on my boat. They are harder to spin than my 26 Bravo One, I’m going to sell them. There soppose to be really nice sought after props.
1MOSES1 05-18-2020 09:29 PM
yea should run about 70 or so...
Griff 05-19-2020 12:11 AM
Keep in mind, the 292 Fastec's came standard with 1.65 ratio drives. Pretty sure Formula did this due to issues getting on plane.
02Formula33ss 05-19-2020 05:11 AM
I’m going to try a set of 26p and see what happens.
rvtransport 05-19-2020 11:49 AM
I had 292 with 6.2s and 28 bravo 1 mercury racing lab finished is the prop to run. Knew a guy with same boat had 5.7s like yours and he was also running 28 labs and worked well. Being your at 4950 already 28 labs should bring you to 5200 which is perfect for your motors. It will run 70 plus with right prop.
rvtransport 05-19-2020 12:00 PM
02Formula33ss 05-19-2020 12:22 PM
I think I’m going to send these out to be labbed
02Formula33ss 06-01-2020 01:00 PM
Got to run the boat again this morning with no wind and light current. Made it to 68 trimmed out but still just shy of 5k rpms.
should I go down to 26p FS ?
Griff 06-03-2020 03:08 AM
No. You would be better off to have your props labbed by BBlades
02Formula33ss 06-03-2020 07:07 AM
I’ve been trying to get a hold of them for a week now.
PA.WOODCHUCK 06-03-2020 07:41 AM
not easy to get hold of them this time of year. use the contact form and wait or run your current props until the off season special they offer?
https://bblades.com/contact-us/
Revspan 06-06-2020 08:33 PM
I have been down the exact same path as you. everyone with a 292 says they are easily 70mph boats...my experience is totally different.
I bought my boat as a Formula demo boat with 20 hours on it. It is a 2014 model with 6.2 mags. Has 1.65 drives, and sea core.
I have a set of brand new 26 B1s, 28p B1s, and labbed 28p B1s that BBlades did for me. The boat came with labbed props, but has Brett redo them. They even have vent holes drilled in them to help get on plane....which by the way does not really help.
I run mostly on Lake Cumberland, so it is pretty big water. A long lake that gives you miles to run. So...with all the props to choose from, what do I run?.... 26p for the last 3 years. Stock 28p are impossible to get on plane with any load and a heat soaked engine compartment.....not really impossible, but embarrassingly slow. Labbed 28p are awesome once you get on plane, pull hard in midrange, and let the engines scream right to 5200....they are great.....just really hard to get out of the hole. Have 4 people in the boat and they are a bad choice due to hole shot.
i never boat alone, and rarely have 1/2 tank of fuel, but always a cooler and stuff for day trips. Intentionally run the boat on the light side as I keep it on a trailer and can fill up before launching.
in the end, if your goal is only top speed...get the 28s labbed...but beware, it will be even harder to get on plane than the stock 28p. Also...if you boat in hot weather, when you shut down, the engine compartment gets hot an robs power until you get running and cool it down.
Just got back from the lake, and with the Bimini up, 4 people and various stuff in the boat with 1/2 tank of fuel(60gal), I could hold 50 at half throttle...and over 60 at WOT with ease.
I can say that I have never seen 70 in my boat with any prop combo. Yes, I know how to drive, and have tried....but gave up. Maybe my ECT engines don’t make the power....but I am pretty sure people reporting over 70 are not using GPS....or they have 5 gal of gas in salt water, with the wind, 1’ chop with the current and only the driver in the boat.
F14A water jet 06-07-2020 07:57 AM
Do Boats Go Faster In Saltwater Or Freshwater? All other factors being equal (boat type, water temperature, weather, weight) boats will travel 1-2% faster in freshwater environments. This is because the density of freshwater means less resistance in the water.
02Formula33ss 06-07-2020 01:01 PM
Thanks for the right up. Great info! What’s your cruise speed with the 26p ?
Revspan 06-07-2020 02:34 PM
I usually cruise around 3700-4000 rpm, at around 40mph. Drop below 40mph and you will add enough drag that you will begin to come off plane. Cruises at that speed with great fuel economy.
I have a long series of posts on the topic of props and cooling if you want to search for them. Went and looked at them, and now remember that with a light load, and good chop, I could only get 69mph with the labbed 28p B1s. Tabs neutral to a little up, 1’ chop, and trimmed to get beat speed. Unlike my last boat, 260 PQ, the stepped hull really likes neutral trim. No use in adding a lot, it just takes speed away.
Griff 06-08-2020 01:40 AM
Less drag going through the fresh water but since salt water is more dense, the boat sits higher and rides on top more.
Temp, humidity and elevation are more important factors.
