Cigarette Bullet Kiekhaefer hatch pump problems on Cigarette Bullet
I have a Cigarette Bullet and the engine hatch has been having issue going up. Usually the solenoid clicks and the motor runs but the hatch doesn’t move for first few times then if I let it sit for a minute it of two it will go on up. I thought it might be low on fluid. I got access to the plastic cap/dipstick on the side of the pump and added some fluid to the full mark on the dipstick with the ram extended. Now the ram doesnt go up or down. Does anyone see a flaw in my process? Does the system need to be bled? Thanks
thanks for the reply. I did leave the cap loose for it to vent. Now the motor seems to run as normal if I select down, but the hatch does not move and it seems to be working hard when I select up, but doesn’t move that way either.
A small update. I cracked the line on the pump to let the hatch come down. Once I got the hatch down I checked the fluid level and filled it to the desired level. I then ran the hatch up and it went up with no problem but will not come down. Do I have an air lock of sorts? If so is there procedure to clear it? Thanks
