Calculating overhead door height
Looking at a 30' cruiser and trying to determine if it will fit thru a 12' X 12' shop door.
Bridge clearance is 9'8". Draft with drives down is 35". Can I just add two numbers together? Figuring on the trailer, drives will be pretty close to touching the ground if they are trimmed all the way down. |
I doubt it will fit under 12' high door.
Yeah, not looking good. Appears I'm at least 8" too tall. Probably closer to a foot. Next shop is getting 16' walls.:cool-smiley-027:
Just out of curiosity, when a boat manuf states "bridge clearance", does it refer to top of structure or top of factory mounted options on top of arch? Not that it would help in this case. |
Bridge clearance should be waterline to highest fixed point.
| All times are GMT -5. The time now is 11:56 PM. |
