Changing the deck from one boat to another?
So my little Baja I don’t use the open bow, and want a lower slung windshield. There is a boat near me for sale that is the closed deck version, judging by the shape of the boat, all of the wood will be bad. At the price the owner is asking I should be able to part out the 4.3/alpha combo, take the deck, scrap the hull then sell the trailer and come out a little ahead.
My question comes into putting that deck onto my hull. Pretty sure from the pictures that the boat for sale has the same hull as mine which was common for Baja to use them over several models at a time. I am going to be fairly certain in my guess that the pop rivets holding the deck and hull together will not line up. Is this something I should just match whatever ones I can and then redrill the hull to match the new deck and hope I don’t add enough holes that I weaken that section of my hull? Should I get everything filled on the hull and then re drill to match the new deck? Yes, I know this makes no sense for this boat, however I have a big emotional attachment to it, I got it for free during my parents divorce and will probably be 50k in the hole on it when redone this go around. In the end it’ll be the people in my wills problem to deal with haha. |
Sounds like an ambitious project.
In general pop rivets are not a great way to hold a boat together even though it is common. If you take the time to prep & clean the outside of your hull and the inside of the new deck at the joint you will have a much better result if you use an adhesive in addition to the pop rivets. Something like Plexus or even 3M 5200. I don't think the extra holes will matter. |
Easy task if the seam matches and as said above use adhesive.
I have zero experience on the subject but have read that’s it’s really critical to support and stabilize the hull before popping the top or it’ll flounder out of shape.
There’s a few folks from the original baja factory on the FaceBook Baja groups that can probably tell you exactly what needs to be done and how. |
I was very close to doing a deck swap or build in my 32 spectra. The hull was my ideal length and absolutely loved the way it handled and crushed the waves. Downside was the deck was butt ugly.
Regardless I had thought through what my plan of attack was going to be and I agree rivets are kinda worthless and I was going to use 5200 and through bolt. I even considered glassing in addition. Not everyday you need to swap out a deck so the stronger you bond it the happier the boat will be. My 28 saber and 28 challenger were both done in similar fashions right from the factory. Prior to removal a little bracing not a bad idea. No need to overkill. I remember people poking at me for doing the same but really not that big of a deal as long as you have the place to do it. Just take your time and think things through before acting. Good luck and keep us posted. |
Originally Posted by Mbam
(Post 4769066)
Originally Posted by Baja Rooster
(Post 4769081)
Originally Posted by getrdunn
(Post 4769082)
Regardless I had thought through what my plan of attack was going to be and I agree rivets are kinda worthless and I was going to use 5200 and through bolt. I even considered glassing in addition. Not everyday you need to swap out a deck so the stronger you bond it the happier the boat will be. My 28 saber and 28 challenger were both done in similar fashions right from the factory. Prior to removal a little bracing not a bad idea. No need to overkill. I remember people poking at me for doing the same but really not that big of a deal as long as you have the place to do it. Just take your time and think things through before acting. Good luck and keep us posted. Want to have the new deck off prior and get the HIN removed. These boats had the HIN on both the hull and deck right above and right below the molded in swim platform. Have dealt with enough issues on this kind of crap that I’m not doing it again. |
Just don’t ask for any recommendations from formula!!!!
:party-smiley-004: |
Originally Posted by 1MOSES1
(Post 4769138)
Originally Posted by tmmii
(Post 4769148)
They haven’t been mention in this thread. Perhaps you should start another one in the beware section.
no sense of humor on these boards...:hitfan: |
If the donor and your hull are the exact same hull, you will have to measure the hulls (X,Y & Z) to verify the fitment as different models that are from the same hull/ same mold, can have different side heights that will be the difference between the new deck fitting directly and the potential for a lot of fitting, cutting and more discouraging - 2 tore up hulls
If the sides are different in height/cut profile, the decks will be designed to fit accordingly. Loft the hulls and see what comes up, it may be very straightforward deck swap. Having the pop rivets should make a clean removal of the decks (drill heads and punch through). +1 on the 5200, the more solid the bond the better the outcome. |
