-   -   Full hydraulic steering (https://www.offshoreonly.com/forums/general-boating-discussion/371218-full-hydraulic-steering.html)
Donskihp 04-16-2021 08:55 PM
My cigarette has Marine Machine hydraulic steering. I need to re plumb my steering system, I have 2 active power steering pumps. What is the best method for hooking up pumps? Do I just tee both pressure lines up together and the same for the return lines?
my steering system is made by Marine Machine, which was located in Opa-Locka Florida, are they still in business and where are they now. I can’t find them on google
flat rate 04-16-2021 10:42 PM
Both pumps should go to a priority valve and then -8 line to the helm. The return line should go to a fluid reservoir.
Griff 04-18-2021 12:12 PM
Marine Machine is no longer in business. Imco sells what you need if you want to run 2 pumps.
Personally, I'd just run one pump.
Sick Stinger 04-19-2021 12:35 PM
if you need the split valve i have a few from latham
Donskihp 04-22-2021 10:03 AM
Any idea where to get the priority valves?
242LS 04-22-2021 10:17 AM
You may have known this, but just in case.... I found out the hard way - the filter has a check valve in it, so designed to flow in a single direction. Don't put it in backwards. :picard1:
TICafeRacer 08-02-2021 04:24 PM
Marine Machine Ram or rod
I have a 35’ Cigarette Cafe Racer with Marine Machine steering. The port ram has a “pit” in the rod and is leaking. Does anyone have a ram for sale from Marine Machine. The whole ram or the rod would be greatly appreciated.
https://cimg6.ibsrv.net/gimg/www.off...dc4e241f4.jpeg
cig28 08-03-2021 07:29 AM
Here is the email to the owner of marine machine his name is Byng Goode. He still has equipment for sale I just purchased seal kits for my rams and a PS reservoir. [email protected]
TICafeRacer 08-07-2021 06:53 AM
Thanks very much. I just saw this. I’m not sure how I missed it previously.
