We appreciate the respect, however Mercury put a lot of $ and time into building this. I'm not saying it's the greatest thing in the world, and never breaks, or never fails... but statistically, it works...
If you insist on making a new hole, I'm sure you can, but I'm telling you from (my personal) experience... sometimes modifying stuff like this... the juice ain't worth the squeeze man... I've been there. done that. lots of things. Learned that often making the system back to 100% original/factory/etc is the best thing you can/should do. Just honestly trying to save you hassle, time and money :). But it's your boat if you really want to make some holes.. just let us know how it goes and get some pics please! |
You`d need a strainer and a blow off valve.
YOu can`t control pressure thru some loop or a partially open shut off. It doesn`t work that way . Unless you have a midget in there to open the valve when you`re going slower and almost close it when you`re going faster and adjust everywhere in between. Adjustable pickups would work also....still need a blow off and strainer But this whole thing is unecessary as mentioned |
Don't reinvent something that works... that's Mercury's job(LOL)!
Originally Posted by Boatally Insane
(Post 4786449)
Depending what engine / display setup you have you may ALREADY have access to view water pressure.
( I can see it on my Simrad connected to 525's) Or install a gauge in one of the block drain ports. THEN install an adjustable transom mounted pickup.. Adjust the pickup depth to achieve the desired water pressure. I had thought about looking into the VesselView by Mercury which might show water pressure but not sure if my engine is compatible or how to hook it up. |
Originally Posted by ICDEDPPL
(Post 4786451)
YOu can`t control pressure thru some loop or a partially open shut off. It doesn`t work that way . Unless you have a midget in there to open the valve when you`re going slower and almost close it when you`re going faster and adjust everywhere in between. Adjustable pickups would work also....still need a blow off and strainer But this whole thing is unecessary as mentioned I already have a basket strainer but was looking for something integrated with the pickup, because the strainers are bulky and hard to fit behind the engine |
Originally Posted by SabrToothSqrl
(Post 4786450)
Originally Posted by boater24178
(Post 4786456)
What places sell the blow-off valve? All the sites I looked at to buy transom pickups dont show anything like that.
I already have a basket strainer but was looking for something integrated with the pickup, because the strainers are bulky and hard to fit behind the engine https://teaguecustommarine.com/em001...e-relief-valve How would you clean something intergraded with the pick up ? Basket is your best choice |
2 Attachment(s)
The strainer should be installed somewhere accessible, depending on where you boat, it may need to be cleaned frequently.
Teague has great information. |
(Post 4786445)
I can partially open it and that should reduce the pressure correct?
Originally Posted by Eddienel
(Post 4786457)
The juice ain’t worth the squeeze! Love it! Can’t wait to use it!!!lol
Also, if you migrate to a transom fitting for the water in, I would guess you'll have to remove the drive and bell housing to remove the hose that runs from the housing, to the transom, and or find a way to plug that hole, which I assume if left open, would fill the boat with water fast at speed! |
| All times are GMT -5. The time now is 12:40 PM. |
