-   -   Center consoles (https://www.offshoreonly.com/forums/general-boating-discussion/372539-center-consoles.html)
Rockpile5 07-17-2021 12:15 PM
Center consoles
I am debating between a 34 Sunsation or a 34 nortech
noli 07-17-2021 12:18 PM
maybe this can help?
Stuckonstupid 07-17-2021 12:29 PM
Discussed heavily here:
https://www.offshoreonly.com/forums/...le-advice.html
noli 07-17-2021 12:37 PM
36Tango 07-17-2021 04:52 PM
Where do you do most of your boating? Will it be used for fishing at all?
Ing 07-20-2021 08:12 PM
Compare core materials and layup. Make note the Nor Tech gives you details about their construction. Sunsation, not so much.
caseyh 07-21-2021 12:08 PM
after being on both boats its hard to say. go ride on them and see what you think.
21 Hustler 07-21-2021 05:22 PM
curious as to why the 34 nor tech is made offsite and just finished at the factory, vs the rest of the lineup which is all done at the factory. Does someone else build the 34? Is the construction different?
erik1976 07-22-2021 10:39 AM
Only has to do with space. The 34 is mostly rigged at the old facility, same place all the boats used to be rigged. its the perfect sized shop to rig a 34 but once you got a bunch of 39's and 45's in there it was packed. The old facility still houses the glass shop and paint booth for all models and most of the rigging on the 34. The construction of the 34 and 39 are the same and all done by Nor-Tech.
hogie roll 07-22-2021 12:25 PM
I’d go nortech
Knot 4 Me 07-22-2021 09:59 PM
I like them both but if you can swing the wait/price Nor-Tech in a 34. Sunny shines in their 32. And the 34 is awesome in twins if you aren’t running way offshore. 400’s get you almost 70 mph. If ya can swing twin 450’s even better.
