What does this mean??? need tech help >
Old 11-19-2002 | 09:14 PM
blown formula's Avatar
Hey Packin'....
now you know why you got laid off.... so you could work on the boat!!! No really, that's what you get for skippin' out on your other "major freak out thread" while we are all busy roasting you!!
Sorry about your troubles man, I been there too.
blown formula is offline
Old 11-19-2002 | 09:27 PM
johnnyboatman's Avatar
check drive had it happen 1 time thought motor locked up sounded real bad , pulled drive fired right up. something in drive let go started w/lite knock ended in thud
johnnyboatman is offline
Old 11-19-2002 | 09:42 PM
Ratchet's Avatar
Default Re: What does this mean??? need tech help
Originally posted by packinair
............then there is an annoying ticking that got louder..........
If this is really an outboard as 26 scarab illuded to, then I know exactly what it is. There is a little warning sticker on the flywheel that the corner peeled up on.............while it's spinning around, it's hitting the case.
Just peel it off
Sorry had to.........just winterized the fishin boat w/ the outboard
Hope you get it straightned out soon
Ratchet is offline
Old 11-19-2002 | 09:56 PM
packinair
Originally posted by catmando
eMotiondriver,
You have a TRIPLE turbine boat??? got pics?
I think Doug has a big bump on his head as well
Old 11-19-2002 | 10:04 PM
X-Rated30's Avatar
eMotiondriver,
With muffler bearings???
X-Rated30 is offline
Old 11-19-2002 | 11:30 PM
ChrisK's Avatar
Moderator
eMotiondriver,
And flatulator valve connected to the muffler bearings that are part of the sub-atomic regenerator.
ChrisK is offline
Old 11-20-2002 | 09:49 AM
Wally's Avatar
Were doomed!
The turbo cybernetic homoginator may need to be topped off with blinker fluid........or the glove box metering valves may be missing.....
-Wally
Wally is offline
Old 11-20-2002 | 09:53 AM
CRUBOSS
whatever it is i know one thing.......IT WON'T BE CHEAP !
Old 11-20-2002 | 10:18 AM
RickerTX
definitely won't be cheap
Old 11-20-2002 | 10:19 AM
GeeterB's Avatar
Default HUH-OH
Wally just called you a HOMO
GeeterB is offline
