-   -   496 HO water flow issues (https://www.offshoreonly.com/forums/general-boating-discussion/372662-496-ho-water-flow-issues.html)
c_loud 07-26-2021 10:18 AM
Tapping into the wisdom of all on this great forum. I dont know where the ockage is but my water will not flow into the heat exchanger and through the exhaust. I can get it to come up to the heat exchanger but it won't flow through it and into the exhaust. I did backflush it and then forward flush it as well which did shoot out some small wood fragments but the line allowed water to flow cleanly through. There was some small pebbkes in the right hand side of the heat exchanger which were all removed but i still cant get the water to flow completely through. Ive heard about the inlet hose collapsing but mine is so stiff, it is tough to collapse it with tools so i dont think thats the problem not to mention my alarms go off before i can get a good look at very many items at a time.
underpsi68 07-26-2021 10:57 AM
I would first take the end plates off the coolant heat exchanger to start. The rubber gadkets are know to warp and block flow.
Gunrunner72 07-26-2021 11:06 AM
When you think you've backflushed enough, backflush some more.
PA.WOODCHUCK 07-26-2021 12:06 PM
If you want an water flow diagram do you have cats or not then email me at [email protected]
