-   -   Help, any Ideas? (https://www.offshoreonly.com/forums/general-boating-discussion/372777-help-any-ideas.html)
NevadaSmith 08-02-2021 11:12 AM
Help, any Ideas?
2000 342 Performance. 2 years ago, rebuilt Starboard 502. It is like new, runs perfect. This spring I rebuilt the port 502, by the same shop that has been around for years and years with a great reputation. Sounds and runs well but will not make the same top end. WOT Starboard RPM 5000, Port RPM 4500+ almost 4600. We have checked everything and are out of ideas.
Help please
Lenny
underpsi68 08-02-2021 11:35 AM
I would start off checking fuel pressure, timing and take a look to see what the spark plugs look like.
Griff 08-02-2021 01:37 PM
List the "everything" that you checked.
NevadaSmith 08-02-2021 02:34 PM
fuel pressure, timing, new plugs,fuel injectors redone,switched tacs, switched ECMs, checked the prop. Thinking about switching drives. going to change throttle cable.
Griff 08-02-2021 07:35 PM
Swapping drives will do nothing unless one of them has external damage.
Make sure the throttle cable is adjusted properly. Pull the flame arrestor and make sure the the throttle body flap is going to WOT. Unless the cable is hard to move, changing it will do nothing.
Did you check fuel pressure while running at WOT??
NevadaSmith 08-02-2021 09:02 PM
Fuel regulator was replaced with an adjustable one. A gearhead friend says it should be 40PSI. it is set at 44psi at idle.
NevadaSmith 08-02-2021 09:03 PM
So the answer to you question is no. Not checked at WOT
Griff 08-02-2021 09:26 PM
43 psi is the stock setting and it should maintain that at all rpms. It needs to be checked while running the boat in the water under load.
NevadaSmith 08-02-2021 09:29 PM
I will try to get that done this week. any other ideas?
Wally 08-03-2021 08:04 AM
Another avenue to look at is the props....i had one prop from a set that were supposed to be 23p each......problem was that one prop had blades closer to 24.5P and it was loading the motor down too. They must have been worked at some point but you couldn't tell just by looking at them
zz28zz 08-03-2021 10:58 AM
Nice thing abt having 2 engs is you can swap stuff around to troubleshoot. I would start with ign components; coil, dist, external spark boxes if applicable.
Make sure spark plugs and gaps are the same between engs. 0.035" would be a good place to start.
JaayTeee 08-03-2021 01:26 PM
This
Swap props from side to side and run it( your shifters will be backwards)
and see what it does
