From what I have ready the engines themselves are identical insofar as the powerhead is concerned...so yeah, Merc must be doing some 'black magic' on a normally aspirated engine to get 50 more ponies...either that or they radically DE-tune the 250 hp version.
Originally Posted by bajaman
(Post 4801619)
Originally Posted by LIQUID THUNDER
(Post 4801622)
One only needs to look at the MAX RPM Limits of the 250R vs the 300R to see how the "Black Magic" is done to make 50 more HP. I am certainly no expert on this, but it seems like that it how it is done.
https://cimg1.ibsrv.net/gimg/www.off...5355db4a6a.png |
I was looking at the "R" motors specs, they have different max rpms, for a 250R vs 300R, not the regular V8 motors. Sorry about that.
That is strange that they have same everything but HP rating. |
(Post 4801636)
The PRO XS all rev to 6,200, the 250 Pro XS is the same as the 250R power wise (270 ish HP). The 300R has different cams, intake, ecu; makes significantly more than 300 HP. The regular four strokes have different exhaust and tuning. They may have different intakes but I don't know for sure.
The HP difference between a 250 ProXS and 300 ProXS is small, not worth messing with. |
(Post 4801615)
I thought both were NA, seems like a lot of HP out of just a tune.
Originally Posted by rak rua
(Post 4801607)
Taking a 1,000 hour engine and increasing its power by 20% would surely put more stress on everything. I reckon you’d considerably shorten the remaining lifespan of many components. They don’t get stronger after 1,000 hours of use. 🙂
Could it be done….? Probably, but in commercial use, I think you’d regret it down the track. RR |
Originally Posted by DrFeelgood
(Post 4801602)
Wish I knew. But none of the shops who used to be willing to flash Verados are willing to do it anymore. Mercury and the EPA have aggressively shut it all down and their effort seems to have been effective.
I know a lot of the smaller engines are identical except for restricting air flow.
I had a Yamaha 9.9 that I made into a 15 with just bending the Reed cage to let the reeds open more. After that instant 5hp. Just bought a 20hp mercury 4 stroke. Both the 15 and 20 are the same except for air restrictor (washer) installed in air tract to restrict flow and a different programed ecu (efi). They charge quite a bit more for the 20 than the 15, but the cost of a new ecu was double what buying a new 20hp ecu was. This is very common with out boards. I could list a lot of engines which are just about identical with different hp ratings. I don't know much about the engines you are asking about. I would post over on the hull truth. A lot of outboard guys there. I'm sure someone could give you the answer. |
| All times are GMT -5. The time now is 07:45 PM. |
